Cupboard doors either side of chimney
Old 04-06-2008, 9:20 PM   #1
PulsarPilot's Avatar
3,702, Level: 14
Points: 3,702, Level: 14 Points: 3,702, Level: 14 Points: 3,702, Level: 14
Thanks: Gave 83, Got 15
I am planning to build cupboards with shelves above, either side of my chimney breast, but have no idea where to get suitable doors from. I am thinking of either pine/oak to be painted/stained,or perhaps something a little more modern, perhaps something glossy, or some sort of panneling.
Any ideas or links would be much appreciated
Old 04-06-2008, 9:33 PM   #2
celtic13's Avatar
5,119, Level: 16
Points: 5,119, Level: 16 Points: 5,119, Level: 16 Points: 5,119, Level: 16
Thanks: Gave 79, Got 41
Re: Cupboard doors either side of chimney
If you have a look at my thread I did exactly the same on one side of the chimney breast, I built the cabinet from mdf but bought the doors from good old b&Q.
Paul
PulsarPilot (05-06-2008)
Old 05-06-2008, 5:48 PM   #3
3,702, Level: 14
Thanks m8,that looks very nice
I have looked in b+q in the past,but could not see any doors suitable, your's look perfect though (if I can get them in the right size). Do you have any more pictures of the finished room, or any problems you found, especially regarding working with, and painting MDF?
Cheers, Dave
