Wall fixings
Old 02-06-2008, 7:07 PM   #1
2,556, Level: 11
Points: 2,556, Level: 11 Points: 2,556, Level: 11 Points: 2,556, Level: 11
Thanks: Gave 16, Got 3
Wall fixings
Going to build a false wall to encase my lcd i got some wood batons and mdf boards i also got 200 frame fixings 100mm, i just would like to know which screws would you recomend to fix the mdf to the wood batons
Old 02-06-2008, 9:49 PM   #2
tmurphy's Avatar
6,167, Level: 18
Points: 6,167, Level: 18 Points: 6,167, Level: 18 Points: 6,167, Level: 18
Thanks: Gave 3, Got 37
Re: Wall fixings
I'm using 1.5" No8 self tapping wood screws for fixing 12mm MDF.
The positions were countersunk before fixing and filled afterwards with P38 filler.
Tony
Old 02-06-2008, 10:08 PM   #3
2,556, Level: 11
Re: Wall fixings
Thanks for that screwfix have a pack of 200 for £3.47 will try them
