Shortly after, our new speakers and amp turned up and it was time to put more cables into the wall!
Our new Acoustic Energy Aego T satellite speakers
And HUGE subwoofer
We fitted the front left bracket first and made a hole for the cable to go down to our previous hole made earlier.
All the cables come out here.
We then put the speaker onto the bracket.
And were pretty pleased with the result.
Then we did the front right speaker.
Looking good, shame about the mess below.
Ah, all sorted now.
We decided not to mount the centre speaker on the wall for a couple of reasons. Firstly, there isn't a huge amount of space between the top of the cabinet and the bottom of the TV and we thought it might look a bit cramped. Secondly, the way the brackets work, the speaker would be pointing downwards but if on a flat surface, it would point upwards. Due to the position of the speaker we decided it would be better pointing upwards than downwards.
Next we had to do the rear speakers which was a little trickier. We took off the edging strips covering the gap between the edge of the laminate flooring and the skirting board and ran the cables in the gap. We used really small QED Micro cable so it would fit without any issues.
The only other thing we had to work out was how to get the cable from under the laminate floor edging strips and into the wall upto the speaker so we decided to drill a hole in the top of the skirting and one behind the edging strip and somehow feed it through. After a lot of messing about it did finally work but we had to cut a little bit of the wall out till we found a hollow area to feed the cable into the wall.
We made what we named a "service hole" to make finding the cable in the wall easier so we could get it out of the top smaller hole. This service hole is covered by the speaker bracket anyway so it didn't matter. We also used some nice white cable entry/exit plastic pieces to make it look neater.
Next we hung the rear speakers.
And we were happy with the final result.
We still have a few bits left to do such as filling/sanding/painting the cuts we made in the wall and fitting the brush wall plates where the cables come out behind the cabinets and TV wall mount.
We are also thinking of a way of hiding the sockets that sit just above the cabinets. It's a shame in new houses they put all the sockets so high up! If anyone has any suggestions on this one apart from moving them then please let us know!
Hope you enjoyed this post and let us know what you all think.
