Floating wall of a Million Colours
Old 02-05-2008, 10:01 AM   #1
dclayton's Avatar
3,557, Level: 14
Points: 3,557, Level: 14 Points: 3,557, Level: 14 Points: 3,557, Level: 14
Thanks: Gave 57, Got 44
Thanks to groove for the idea, and sworrall for the details on fixings, I started preparing for and making a floating wall quite a few weeks ago.
This is how the wall looked previously:
And after buying 15 meters of optical and DVI to HDMI cable, we moved the computer desk:
The wall spans about 3 meters, so we purchased two 140cm TV benches, reduced from £399 to £99 each in a local furniture shop:
Cleared the area:
New benches in place.
As you can see, the space is limited between the left bench and the sofa, so I didn’t want to extend the floating wall to the floor reducing the space further. The floating wall will sit a few millimetres above the top of the benches.
TV off the wall and outer frame up. The frame is 2.4M wide and 1.3M High with around 30cm of wall around the edge for the light to shine on:
A tip when drilling into walls; tape an envelope just below the hole to catch all the dust:
I had fun at B&Q when buying the MDF, got the two pieces cut to size, 1.25M x 1.35M (to leave a 5cm over hang around the frame). Took them to the car to find they were about 2cm too big to fit. So had to take them back in and get them cut in half, hence the horizontal frame supports below:
The MDF attached:
And then filled. I used £1 filler from poundland and it’s actually quite good quality (they also do big packs of sandpaper for £1).
The comfiest sofa ever and new large coffee table:
End of the weekend so TV back on the wall and rope light attached:
We have some blue LED Christmas lights around the ceiling that we have kept up because they create a nice mood light for watching movies. I wanted to take these down, but still have a blue light, so I purchased the blue version of the rope light from TLC to mount next to the white rope light, but this isn’t bright enough to even shine beyond the 4cm of overhang
I then started looking at alternative lighting, and decided the cheapest way would be to use an PC power supply and connect a number of these to it around the frame.
About to purchase a load of blue led strips, I found another ebayer selling 5 Meters of RGB LED light strip, with power supply, light controller and wireless remote
The pictures of the lights on ebay don’t look very bright, but I bought them anyway for £109.99 and received them two weeks later (they come from China):
The remote:
Power supply and light controller:
5 meter reel of RGB LED strip:
Close up of the strip:
sworrall (03-05-2008), VoodooK1ng (18-07-2009)
Old 02-05-2008, 10:02 AM   #2
dclayton's Avatar
3,557, Level: 14
Re: Floating wall of a Million Colours
And now for some pictures of the strip around the frame. It comes with 3M adhesive sticky backing but I’ve used blu tack for now as I still need to sand, prime and paint the wall and MDF.
The controller can select between 7 static colours: white, red, blue, violet, green, yellow and turquoise, it can flash between these colours at varying speed, or fade gradually with speed control through 1 Million colours !!!
Searching online further at what is possible with RGB LEDs, my next plan is to create a Phillips ambilight type feature with all the content I play off the PC. Take a look at http://www.ambilight4pc.com/ and the MoMoLight and AtmoLight projects for what is possible!
If anyone reading this is competent at electronics, and would be able to make me a working MoMolight or AtmoLight micro-controller, please get in touch!
I still have a lot of work to do and will post some more pictures in a couple of weeks when it’s finished.
Old 02-05-2008, 10:56 AM   #3
2,310, Level: 11
Points: 2,310, Level: 11 Points: 2,310, Level: 11 Points: 2,310, Level: 11
Thanks: Gave 36, Got 54
looking good so far. Like the idea of the LED strip, but it's a whole lot pricier than the good old tlc ropelight!
Old 02-05-2008, 11:53 AM   #4
dclayton's Avatar
3,557, Level: 14
Thanks. LED's are more expensive, £100 rather than £20. But it works out cheaper per colour:
Rope light = £20 per colour, LED = 0.01p per colour
Seriously though, they also consume a lot less power, 2.4W per meter rather than 16W per meter, and they don't give out any heat (or rubber smell).
So over 5 Meters and running them for around 30hrs a week @ 12p/kWh:
LED = 19 kWh per year = £2.28 per year to run
Rope Light = 125 kWh per year = £15.00 per year to run
So after about 6 years use (if the rope light lasts that long) I'll be saving money lol
Old 02-05-2008, 6:56 PM   #5
groove's Avatar
20,304, Level: 34
Points: 20,304, Level: 34 Points: 20,304, Level: 34 Points: 20,304, Level: 34
Thanks: Gave 93, Got 161
WOW ! Im loving that RGB colour change........
Great work there , Its going to look stunning
dclayton (05-05-2008)
Old 02-05-2008, 8:39 PM   #6
4,020, Level: 14
Points: 4,020, Level: 14 Points: 4,020, Level: 14 Points: 4,020, Level: 14
Thanks: Gave 4, Got 3
I must say those LED lights look amazing. I am in the planning stage of building my own floating wall (thanks to Groove`s inspiration), and I have been experimenting with LED`s myself for a while now to try and create the colour changing effect. I even had a list of parts I needed and they came to around £250 and thats without them being remote controlled. I have just emailed the guy on E-Bay to see if he can supply me with a 6M length. If he can I will definately be placing an order with him instead.
Thank you very much for posting those pics. As you said yourself it is very difficult to know how much light is given off by various different types of LED but those certainly look impressive and just what I was wanting.
Barry
Old 03-05-2008, 12:31 AM   #7
3,131, Level: 13
Points: 3,131, Level: 13 Points: 3,131, Level: 13 Points: 3,131, Level: 13
Thanks: Gave 18, Got 11
those leds look really good (and bright)! looking forward to seeing more
Old 04-05-2008, 8:55 AM   #8
dclayton's Avatar
3,557, Level: 14
Thanks for your comments, groove & sworrall.
BarryK, glad I could help. The power supply and controller are capable of driving up to 10 Meters of light strip so 6 Meters will be fine, hopefully the seller is also willing to sell the strip in 1 meter lenghts rather than 5 meter reels, you would then just need to solder the two lengths together.
sworrall (26-12-2008)
Old 04-05-2008, 9:22 AM   #9
4,020, Level: 14
I have emailed the seller and he informed me that he does indeed sell 1M lengths at an extra cost of £12/m including p&p. I will definately be placing my order next week.
Thanks again
Barry
Old 04-05-2008, 3:11 PM   #10
1,947, Level: 10
Points: 1,947, Level: 10 Points: 1,947, Level: 10 Points: 1,947, Level: 10
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 3, Got 13
Make sure you box that power supply in something suitable. I don't like the 240v input on screw terminals. Doesn't look safe to me. :-( Nice effect though.
Old 04-05-2008, 8:31 PM   #11
3,140, Level: 13
Points: 3,140, Level: 13 Points: 3,140, Level: 13 Points: 3,140, Level: 13
Thanks: Gave 3, Got 10
I love your logic! When I get to my mid-life crisis and want to spend the life savings on a flash car, can I contact you so you can give me some ideas on how to justify it to the wife?
Old 05-05-2008, 7:18 AM   #12
8,994, Level: 22
Points: 8,994, Level: 22 Points: 8,994, Level: 22 Points: 8,994, Level: 22
Thanks: Gave 6, Got 162
Great transformation, looks amazing
Old 05-05-2008, 11:06 AM   #13
dclayton's Avatar
3,557, Level: 14
Using the same cost saving logic, you could easily justify one of these. 0 - 60 in 3.9 seconds but a massive 135 mpg!
Back on topic, if anyone does have electronics experience, and could make a working MoMolight or AtmoLight micro-controller, please get in touch
Old 16-05-2008, 3:14 PM   #14
4,020, Level: 14
I ordered 10m length of the above LED lights from the guy in China last week. They arrived today and I have just connected them up to test them. Am very impressed with the brightness so far. Can`t wait to try them in the evening when is darker.
Barry
Old 18-05-2008, 1:44 PM   #15
MasterYoda's Avatar
4,233, Level: 15
Points: 4,233, Level: 15 Points: 4,233, Level: 15 Points: 4,233, Level: 15
Thanks: Gave 27, Got 13
OOh now you've got me interested. I'm planning on putting up a false wall myself on my chimney breast and that looks awesome.
dclayton (19-11-2008)
Old 18-05-2008, 1:45 PM   #16
MasterYoda's Avatar
4,233, Level: 15
and if I can get my harmony remote to control it even better!!!
Old 19-05-2008, 5:03 AM   #17
8,994, Level: 22
Which Harmony remote have you got?
Old 19-05-2008, 9:41 PM   #18
dclayton's Avatar
3,557, Level: 14
Barry
Very bright aren't they! It's difficult to take a photo that really shows how bright and colourful these LED's are.
I eventually got around to finishing off the wall this weekend and here are the results:
The Mission speakers look a bit out of place now, so I've ordered a Celestion AVS501 speaker package.
Old 23-05-2008, 11:25 PM   #19
5,534, Level: 17
Points: 5,534, Level: 17 Points: 5,534, Level: 17 Points: 5,534, Level: 17
Thanks: Gave 1, Got 4
While the line of red X's where the photo's should be is entertaining I feel i'm missing something.
Old 24-05-2008, 9:11 AM   #20
dclayton's Avatar
3,557, Level: 14
I've moved the photos to flickr, so should show ok now
Old 24-05-2008, 12:02 PM   #21
plarkster's Avatar
1,782, Level: 9
Points: 1,782, Level: 9 Points: 1,782, Level: 9 Points: 1,782, Level: 9
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 30, Got 37
Hi nice setup - gonna have a go at doing something similar next week. How much was the MDF and wooden battons roughly?
dclayton (24-05-2008)
Old 24-05-2008, 12:33 PM   #22
dclayton's Avatar
3,557, Level: 14
I got the timber from wicks, £12.19 for a 6 pack of 47 x 47mm x 2.4m (didn't need that much for the wall, but got extra to make some shelfs in a cupboard together with the left over mdf). I also got a single piece of 47 x 75 to use where the mdf sheets meet.
I used two MDF boards (2440 x 1220 x 12mm) @ £13.98 each from B&Q.
The total of timber, mdf, fixings, mdf primer and paint came to around £80.
plarkster (24-05-2008)
Old 24-05-2008, 1:07 PM   #23
dclayton's Avatar
3,557, Level: 14
Here's an update photo with the AVS501 speakers:
I think these look much better, and sound quality is excellent too
Old 27-05-2008, 7:25 PM   #24
MasterYoda's Avatar
4,233, Level: 15
525
Old 28-05-2008, 1:28 AM   #25
15,948, Level: 30
Points: 15,948, Level: 30 Points: 15,948, Level: 30 Points: 15,948, Level: 30
Activity: 5.3%
Activity: 5.3% Activity: 5.3% Activity: 5.3%
Thanks: Gave 369, Got 225
Great Job! How good do these new speakers sound? I heard they are very clear and give a very three dimensional sound - what is your opinion? what would you compare them with? Do you use the same ones for the rears? What Sub are you using with them?
Suave!
dclayton (28-05-2008)
Old 28-05-2008, 4:57 AM   #26
8,994, Level: 22
New speakers proportion's look miles better, colours work really well too
All in all a very nice looking setup
Old 28-05-2008, 8:14 AM   #27
1,529, Level: 8
Points: 1,529, Level: 8 Points: 1,529, Level: 8 Points: 1,529, Level: 8
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 4, Got 1
Great Transformation,
Could you post me a link or email address for the supplier of the strips please,
looking to do a similar thing in my bedroom, can you remote control them in any way, suppose through x10 plug in would work.
Many thanks
Dave
Old 28-05-2008, 11:51 AM   #28
dclayton's Avatar
3,557, Level: 14
Originally Posted by Suave View Post
Suave!
I'd rate them as good as the mission m30i that they replaced. They don't move as much air, so are not as in your face, but the quality of the sound is extremely clear and it's surprising how much bass comes out of the little speakers. I'm using these for the rear also. There's seven small speakers in each, 35 of them makes a very nice sound The sub that came with the m30i speaker package is still in use, but I intend to replace this as soon as I can afford to so that I can sell the old speakers together.
Suave (31-05-2008)
Old 28-05-2008, 12:04 PM   #29
dclayton's Avatar
3,557, Level: 14
Originally Posted by dwalker1 View Post
Many thanks
Dave
I bought the 5 meter strip, which comes with a wireless remote and controller from the china ebay seller 'demosworld'. He currently has some for sale at £100.50 including the wireless controller and delivery, or just the 5m length of strip light for £68.95 delivered.
I've recently purchased a different controller that will enable me to plug the strip lights into my computer, and let the computer change the colour of different sections of the strip depending on what is displayed on screen, much like this:
youtube link
I'm hoping to install it tonight and will post more pictures and hopefully a video when done. Will make watching a film a whole new experience
dwalker1 (29-05-2008)
Old 28-05-2008, 6:30 PM   #30
2,422, Level: 11
Points: 2,422, Level: 11 Points: 2,422, Level: 11 Points: 2,422, Level: 11
Thanks: Gave 6, Got 12
Top work
I spy your coffee table, is it leather coated and where did you get it from?
Paul
