Me and my Mrs Chimney attempt
Old 25-04-2008, 9:36 PM   #1
berkeley384's Avatar
4,602, Level: 16
Points: 4,602, Level: 16 Points: 4,602, Level: 16 Points: 4,602, Level: 16
Thanks: Gave 68, Got 78
Hello, was going to wait till it was done as it may be quite a while till I get the flooring down and the frame plastered but thought I'd show off where we are up to so far
Firstly here is a pic of our nasty old fireplace ...
SO, firstly old fireplace out and hole blocked up ..
Basic frame put up ...
Purchased bracket ...
Made a hole for the bracket ...
And then mounted it ...
Finshed off the frame and mounted the TV ..
Tomorrow we'll be plasterboarding it hopefully , then we can crack on with a new floor etc
Anyways, thanks for looking, any comments welcome
Old 25-04-2008, 9:52 PM   #2
3,616, Level: 14
Points: 3,616, Level: 14 Points: 3,616, Level: 14 Points: 3,616, Level: 14
Thanks: Gave 14, Got 21
Re: Me and my Mrs Chimney attempt
Looking good What are you changing your flooring to? Your floorboards look nice as they are.
Old 25-04-2008, 11:19 PM   #3
2,836, Level: 12
Points: 2,836, Level: 12 Points: 2,836, Level: 12 Points: 2,836, Level: 12
Thanks: Gave 24, Got 26
Looking forward to the finished job.
Old 26-04-2008, 12:24 PM   #4
1,660, Level: 9
Points: 1,660, Level: 9 Points: 1,660, Level: 9 Points: 1,660, Level: 9
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Good to see people are mounting their TV's at a lower-more-on-level-with-their-eyes-when-seated-height in the real world - I'm so tired of seeing picture/mirror height installs on chimney breasts in advertisments and through people's living room windows.
Old 26-04-2008, 2:20 PM   #5
4,114, Level: 15
Points: 4,114, Level: 15 Points: 4,114, Level: 15 Points: 4,114, Level: 15
Thanks: Gave 1, Got 5
is that a live gas pipe in the wall? just curious as its yellow>?
Old 26-04-2008, 4:17 PM   #6
8,994, Level: 22
Points: 8,994, Level: 22 Points: 8,994, Level: 22 Points: 8,994, Level: 22
Thanks: Gave 6, Got 162
What make is the bracket, it looks a quality item
Old 26-04-2008, 5:04 PM   #7
4,602, Level: 16
Done a little bit more today, but got bored and stopped ..
Basically we've plasterboarded around where the TV sits, tomorrow we will do the lower shelf where the centre speaker will sit .. anyhoo , heres a few pictures ..
Just to be on the safe side the we've put holes in the top piece to add extra ventilation ..
Old 26-04-2008, 5:16 PM   #8
4,602, Level: 16
Unfortunatley the chimnet doesnt come out as far as the fireplace did so we now have a rather latge patch of missing floor - its only laminate anyway so we'll just start over and do it again
Totally agree, if anything it may be an inch or so higher than I'd prefer it, but I wanted to keep the centre speaker at a reasonable height
Yes, well at leatst it was, kind of is, we paid someone to (corgi registered) to come round and take out the fireplace, that pipe goes into the old fireplace hole and has been capped off
Im unsure of the make, I got it from www.bracketsrus.co.uk, it was 49.99 inc delivery, I wanted something that allowed me to pull the TV out to get to the cables behind it and its worked out really well. I wasn't particularly pleased with the customer service from BRU as I asked for measurements of the bracket and several e-mails were ignored and their site lists no contact telephone number. Also when I ordered it I didnt get any kind of confirmation that it had been ordered or that payment was successful etc.
When I eventually managed to get a tel number for them I spoke to possibly the nicest bloke on the planet and it did turn up within 2 days which was good
Old 26-04-2008, 6:36 PM   #9
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
thats all looking really good and I like the bracket as well
keep that blokes no. as I`m sure you`ll be asked for it in the future
keep up with the pics as well
cheers Al
Old 26-04-2008, 10:16 PM   #10
alz2605's Avatar
5,861, Level: 18
Points: 5,861, Level: 18 Points: 5,861, Level: 18 Points: 5,861, Level: 18
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 279, Got 315
Love the work so far! Can't wait to see the end reuslt! I can see this being a great thread! Great TV bracket too! Just what I was looking for the bedroom TV!
Old 27-04-2008, 8:56 PM   #11
4,602, Level: 16
Well we're totally knackered tonight, we've only just finished and its 21:47
We're not your regular DIYers, something of this size of job we'd normally leave to a proffessional. What amuses me most is that I've read through countless DIY projects and thought "is that all they've done". Its quite apparent to me now that this isn't as easy as it looks and is very hard work and is very time consuming.
Anhoo here is some pics of todays work, we got more do than I expected but still quite a way to go...
Firstly we made the box section for the centre speaker, candles, girly bits and bobs etc ...
Then we cracked on makeing the front, this was the bit I was looking forward to the least .....
Mounted the TV and placed the speakers to get an idea of how it will all be when its done ....
Let me know what you think
Old 28-04-2008, 4:52 AM   #12
8,994, Level: 22
Coming along nicely, like the speaker stands
Are you going to tape and joint the plasterboard or skim it?
Old 28-04-2008, 11:32 AM   #13
elootos's Avatar
5,938, Level: 18
Points: 5,938, Level: 18 Points: 5,938, Level: 18 Points: 5,938, Level: 18
Thanks: Gave 224, Got 194
Your build's looking good. Although when I first saw the thread title I thought; why's he called it his 'Mrs Chimney'?
Old 28-04-2008, 12:10 PM   #14
3,541, Level: 13
Points: 3,541, Level: 13 Points: 3,541, Level: 13 Points: 3,541, Level: 13
Thanks: Gave 12, Got 8
For those of you interested (including me!), this is the bracket:
http://www.bracketsrus.co.uk/cart.ph...t_detail&p=109
Old 28-04-2008, 7:27 PM   #15
4,602, Level: 16
Hi tojo, yes that is the bracket I used, however it would seem that in the last few days its gone up in price as I only paid £49.99 fo it.
Regarding plastering, I have called a local firm to come round and give me a quote, It would seem a shame to make a mess of it now by doing a shoddy platstering job.
Once its done I'll report back and advise how they did it and post up some pics.
Stephen
Old 28-04-2008, 7:37 PM   #16
cloudcity's Avatar
29,058, Level: 41
Points: 29,058, Level: 41 Points: 29,058, Level: 41 Points: 29,058, Level: 41
Thanks: Gave 75, Got 50
Top marks so far, looks great.
Old 29-04-2008, 7:55 AM   #17
marshallp's Avatar
4,509, Level: 15
Points: 4,509, Level: 15 Points: 4,509, Level: 15 Points: 4,509, Level: 15
Activity: 5.6%
Activity: 5.6% Activity: 5.6% Activity: 5.6%
Thanks: Gave 6, Got 6
Looking good so far.
Old 02-05-2008, 7:47 PM   #18
4,602, Level: 16
Yay - we have some progress
Finally fitted the top piece to complete the chimney ..
And the plasterer has been and done a wonderful job..
Mounted TV
This gives you a nice idea why I opted for the bracket I did, I can nicely get to the cables behind the TV ...
So here we are looking somewhere near close to
Next I have to put coving around the top to match up to the ceiling.
In an attempt to save money we've decided to pinch the flooring from the downstairs loo to finish off the living room, then we'll tile the downstairs loo which will be much cheaper than buying a whole new wood floor.
You'll see that the centre speaker is missing at the momnet because the plaster is drying , but obviously once its dry and painted it will sit on the shelf under the TV
One thing I forgot to mention to anyone who is chosing the same bracket as I used, whilst there is a variety of fixings supplied with it, I binned them and used Heavy Duty fixings like the ones in the below link ...
http://www.screwfix.com/prods/18356/...e-14-Pack-of-5
Old 02-05-2008, 7:58 PM   #19
alz2605's Avatar
5,861, Level: 18
Activity: 2.3%
That looks the business! I love that bracket more and more every time I see it! Can't wait to see the finished article!
Oh and great idea to rob the flooring from the loo! Just make sure u give it a good clean first! LOL!
Old 02-05-2008, 9:03 PM   #20
2,518, Level: 11
Points: 2,518, Level: 11 Points: 2,518, Level: 11 Points: 2,518, Level: 11
Thanks: Gave 2, Got 0
with that type of bracket how far does it hold the tv from the wall
Old 02-05-2008, 9:16 PM   #21
4,602, Level: 16
The minimum distance from the wall to the back of the tv is 12 cm
I dont know why but the website says its 7cm but trust me... its not
Old 03-05-2008, 6:38 AM   #22
8,994, Level: 22
Looks like they made a great job off the plastering
Old 03-05-2008, 12:02 PM   #23
4,602, Level: 16
The chap that did it has done a fabulous job as its drying out it just looks better and better,
We're of out to buy some stands / CD towers / something to stand the rear Genies on and then I can start to get the 5.1 rigged back up, Stereo sound from the TV is getting on my nerves now
Old 03-05-2008, 2:15 PM   #24
2,836, Level: 12
Great job, can i ask how do you find the genies thinking of getting some my self.
Old 04-05-2008, 11:23 AM   #25
4,602, Level: 16
I think that they're really good, the Subwoofer is really powerful - I've had them for 2 years now and have been really happy with them.
Stephen
Old 04-05-2008, 12:31 PM   #26
2,836, Level: 12
Thanks mate.
Old 04-05-2008, 1:40 PM   #27
2,092, Level: 10
Points: 2,092, Level: 10 Points: 2,092, Level: 10 Points: 2,092, Level: 10
Thanks: Gave 0, Got 9
just a thought
if you fold the inner arms outwards, if poss, instead of them folding to the middle will the tv sit closer to the wall?
Old 05-05-2008, 12:03 PM   #28
DeadEye's Avatar
4,649, Level: 16
Points: 4,649, Level: 16 Points: 4,649, Level: 16 Points: 4,649, Level: 16
Activity: 2.5%
Activity: 2.5% Activity: 2.5% Activity: 2.5%
Thanks: Gave 3, Got 25
Nice cat!
I really like your idea - I think it's better than the floating wall idea. Did you consider putting some lighting behind the TV?
My only problem is that my center speaker is a foot deep and the bass reflex hole is in the back of the speaker - not sure what affect having it in a hole would have although the Pioneer amp should correct most of the sound problems it might cause....
Although I can and have done some plastering, I would have probably made it from MDF - we will probably wall paper ours...
Old 05-05-2008, 12:42 PM   #29
Senior Moderator
Flimber's Avatar
20,331, Level: 34
Points: 20,331, Level: 34 Points: 20,331, Level: 34 Points: 20,331, Level: 34
Activity: 42.4%
Activity: 42.4% Activity: 42.4% Activity: 42.4%
Thanks: Gave 2,914, Got 2,440
Anyone any idea of an outlet which might be selling these at the £49.95 price still ?
Old 05-05-2008, 5:36 PM   #30
4,602, Level: 16
Originally Posted by DeadEye View Post
Nice cat!
I have two persions and the grey one featured in that pic always manages to get in to at least one them
I dont know how they'll come out, but I've taken some pics of the ikea LED strip lights that I've used behinf the TV
I cant take any credit for any of the ideas really, mostly I've just been lurking on here pinching ideas off others, however I do appear to have put the TV at a much lower height than many others. I cant imagine it being any higher, I'd be looking up at it all the time and I dont think I'd like that.
