Building Regs advice - Garage Conversion
Old 23-04-2008, 9:14 AM   #1
6,060, Level: 18
Points: 6,060, Level: 18 Points: 6,060, Level: 18 Points: 6,060, Level: 18
Thanks: Gave 15, Got 5
Garage Conversion - Nearly Finished!!!
FINISHED!
I will take some better photos this week as LG Secret cameras are terrible......................
Old 24-04-2008, 12:50 PM   #2
3,951, Level: 14
Points: 3,951, Level: 14 Points: 3,951, Level: 14 Points: 3,951, Level: 14
Thanks: Gave 98, Got 75
Re: Building Regs advice - Garage Conversion
Originally Posted by RAMONJKD View Post
Hello there, I have been given planning to convert my Garage, and am now tackling Building Regulations..... I have been asked to clarify a few items by building contol and would appreciate any assistance or advice....
They have asked the following things:-
Details of damp- proofing to walls and floor
Can a mebrane be laid under the floating floor or is painting a sealant easier?
Also, will the single skin wall need painting as well?
Background ventilation part F1
Can this either be covered with a vent in the wall or trickle vent in windows?
Heat loss through walls should not exceed 0.3 W/mēK, Floor 0.22W/mēK & Windows 0.18W/mēK
I did this at college but was wondering if anyone had ideas of construction to cover this? I was intending to stud out the walls and fit Celotex but am not sure of the type to use. I was also going to stud the floor and inlay with celotex as well. The Window details i'm assuming i can obtain from the suppler.
Thanks for any assistance or advice!
Clive
try running these past your inspector.
FLOOR CONSTRUCTION
65mm THICK SAND CEMENT SCREED (REINFORCED WITH FIBRE OR D49 MESH) ON 100mm THICK ROCKWOOL ROCKFLOR INSULATION TURNED UP 300mm AT EDGES OR SIMILAR ON 1200 GRADE VISQUEEN DPM ON SAND BLINDING ON EXISTING ASSUMED 100mm THICK CONCRETE SLAB (THE BUILDER SHALL ALLOW FOR THE BREAKING OUT OF A CORNER TO VERIFY THE SLAB THICKNESS TO THE SATISFACTION OF THE BUILDING CONTROL OFFICER)
WALL CONSTRUCTION
SINGLE SKIN BLOCKWORK INSIDE OF GARAGE TO BE INSULATED USING KINGSPAN K18 KOOLTHERM DRYLINED INSLUATION BOARD, OVERALL THICKNESS TO BE 67.5mm INCLUDING 12.5mm PLASTERBOARED TO GIVE TOTAL U VALUE OF 0.3 w/m2k
they should do you fine.
and your right about the windows, just spec the u value when you order them.
RAMONJKD (24-04-2008)
Old 24-04-2008, 2:23 PM   #3
6,060, Level: 18
Nice one! the only issue i may have with the flooring is that i was hoping to keep the thickness to a minimum, Basically the slab of the garage is about 50mm lower than the adjacent living room floor, so was hoping for perhaps a slight step up via a threshold rather than a step.......
Old 24-04-2008, 3:02 PM   #4
3,951, Level: 14
HI again, bored at work so done some digging for you.
The u value you've been told you need to acheive with your windows is .... well to put it bluntly unacheivable.
Luckily for you you've been told wrong, you need a U value of 2.0 for pvc windows.
Your floor u value wants to be 0.25 as well. if you tell me the overall size of the garage, length x width i can do a quick perimeter / area comparison and come up with a more accurate thickness of insulation rather than just picking it out of a table.
Old 24-04-2008, 3:12 PM   #5
6,060, Level: 18
The Garage is 5500*2500mm, Does building regulations state the required window values?
Thanks for the info, its a great help! I will be sure to provide regular updates once i get cracking!!
Old 24-04-2008, 3:20 PM   #6
3,951, Level: 14
you could probable get away with celotex TB3030 with the perimeter / area ratio you have given me, thats 30thk but you'd still need the 65 screed,
you could push it with the TB3020 to gain you another 10mm but its prob best not to.
Building regs state u values for all elements of an extension.
Of course if you want a level floor from living room to garage conversion you could always break the garage slab out, wouldn't add much to the overall cost, prob Ģ500 for the slab and you'd be getting the insulation anyway.
Old 24-04-2008, 7:51 PM   #7
2,476, Level: 11
Points: 2,476, Level: 11 Points: 2,476, Level: 11 Points: 2,476, Level: 11
Your local authority seem to be enforcing different 'u' values to around here. He may be able to avoid screed, It would be cheaper and easier to have a floating floor. Lay 1200 gauge dpm (or asphalt), lay the insulation and then a layer of chipboard on top.
Now as they have asked for damp proofing to the walls, I’m guessing this is a single skin garage and it’s to prevent the ingress of driving rain. You may be required to Cinter Proof the walls which is a horrible job! You’d have to paint it on. It may be best to provide an internal leaf of timber studding with 100mm of Celotex/Kingspan in between voids of timbers. It would achieve a ‘u’ value of 0.3 and the cavity would prevent damp coming through the wall without having to bond the insulation to the masonry.
As for the windows, all they are asking is for the glazing to be 16mm thick, low-e coated and filled with argon. The window manufacturer will spec all that though (leave stickers on until building control inspect to prove adequacy). Trickle vents are fine too.
Might be best to get some bespoke advice form a local architectural practice though as they could come out and see everything. Good luck!
Old 24-04-2008, 8:08 PM   #8
mhuk05's Avatar
14,581, Level: 29
Points: 14,581, Level: 29 Points: 14,581, Level: 29 Points: 14,581, Level: 29
Thanks: Gave 31, Got 128
Have you spoken to your Building Control Officer and asked him what he'd recommend/ like to see (especially as it's him/ her that you'll have to please)?
There's also plenty of practical advice on diynot.com
Old 24-04-2008, 8:32 PM   #9
6,060, Level: 18
Thanks for the response guys. It will be good to resolve all the issues now so i can then just crack on with the conversion.Unfortunately the building inspector didn't seem overly keen to advise on what i should be doing, he just kept refering to what he's asked for rather than specific solutions. The floating floor possibly sounds more practical. I've roughly set a budget so that i've hopefully got cash left over to update some of my kit!
I will try him again and run some of these ideas past him to see what he says.
Watch this space!
Old 24-04-2008, 8:35 PM   #10
3,951, Level: 14
to attain the u value the particular insulation ive spec'd needs the screed, the floating floor he's back to using something like 100 thk insulation. in my experience the screed gives a nice solid floor whereas the floating timber does not.
and as for my local authority requiring different u values, well my local authority use the building reg's, dont yours?
Old 24-04-2008, 9:06 PM   #11
2,476, Level: 11
True, a solid floor is often best but it's difficult to advise when you don't know what the rest of the build is or what budget requirements are. The rest of the house could have a timber floor or even a floating floor anyway and if it was carpeted you wouldn't be able to tell much difference, if any. You'd only need about 75mm of Celotex, not 100mm.
As for my local authority, they usually have their head up their arse! I use a fair few and tbh they are all in line with what the op said
"Heat loss through walls should not exceed 0.3 W/mēK, Floor 0.22W/mēK & Windows 1.8W/mēK"
To the OP, give a different LA a call, some are useful and some aint.
Old 25-04-2008, 7:14 AM   #12
3,951, Level: 14
looks like i'll need to purchase some new building regs,
im still using the 2000 L2 document, i stand corrected.
Old 25-04-2008, 7:21 AM   #13
3,951, Level: 14
Ok design, clarrification please,
Document L2 april 2006, latest issue?
standard u values of construction elements is still as follows,
Table 1 Standard U-values of
Exposed Element U-value
(W/m2K)
Walls, including basement walls 0.3
Floors, including ground floors and 0.22
basement floors
Old 25-04-2008, 12:11 PM   #14
2,476, Level: 11
Yeah, that’s the latest issue. They are all free to download from planning portal. The only other changes are ceilings need to be 0.16 if it’s a flat roof or 0.2 if it’s a sloping ceiling with some insulation under rafters to prevent thermal bridging. Also semi exposed walls such as next to an internal garage now have to be insulated to the same 0.3 ‘U’ value (this may be pre-existing though).
Old 26-04-2008, 8:48 AM   #15
dazzarooney
Posts: n/a
i would highly recommend you visit the celotex website - www.celotex.co.uk..there is a u value calculator.
if the walls are single skin applying a layer of celotex to the wall internally (thickness is dependant on the u value you require) tape the joints with celotex tap, appy vertical battens then plasterboard over...you need to ensure the wall has a horizontal dpc..if not it can be injected.
the thickness of the insulation is dependant to the permiter/area of the garage..again the celotex website has more info on this...most new garages will already have a dpm you need to investigate to see if yours has..if not..you can either use a 1200guage polythene or a liquid asphalt (paint)..synthaprufe or RIW LAC....trouble with the paint ones they smell..and the smell will never go away...if you go down this route..ie..paint over existing slab, insulation, vapour barrier..i would highly recommend a minimum 65mm sand cement screed..alternativly if you already have a dpm under ths slabe..or you wish to go the polythene route..you route would be insulation, vapour barrier then 22mm t&g flooring grade chipboard....if your going to tile the floor..i would recommend the screed..if its carpet or floor board/laminate..the chipboard route is ok
the windows..if your having upvc can easlily acheive 1.8 u value....and if they are new windows get them to put in trickle vents..each habitalbe room needs to have 8000sq.mm of back ground ventilation.
above all, look at the celotex website...or feel free to pm me for clarification..i dont usually visit this side of the forum often.
hope this helps
Old 13-06-2008, 2:13 PM   #16
6,060, Level: 18
Thanks for all the Help guys. The garage was started on thursday last week, and we're now just waiting for the plaster to dry before starting the decorating etc. The fun begins here!!!!
Building Regs advice - Garage Conversion-image069.jpg   Building Regs advice - Garage Conversion-image071.jpg   Building Regs advice - Garage Conversion-image072.jpg   Building Regs advice - Garage Conversion-image080.jpg   Building Regs advice - Garage Conversion-image078.jpg
Old 27-08-2008, 10:59 AM   #17
6,060, Level: 18
Almost finished. Will post proper photos once its completely done. The TV end is only temporary as my joiner friend is on his honeymoon for a few weeks.
The end wall is to be completely panelled in Walnut, with the TV and the Jamo's mounted. There will then be hidden,baby friendly cupboards for the kit!
Edit:- My new LG phone is terrible for taking photos.........apologies!!!!
Old 28-08-2008, 12:24 PM   #18
1,454, Level: 8
Points: 1,454, Level: 8 Points: 1,454, Level: 8 Points: 1,454, Level: 8
Thanks: Gave 2, Got 0
hi
Ive looking through your thread on how you got to the finished product. Im very impressed, i want to do a similar thing to mine, but would have a dividing wall between the conversion and garage door.
If you dont mind me asking how much did this cost, i assume you did most of it yourself, did you do it under a building notice or full plans?
Also how long did you take to complete it, if you did it by yourslef.
cheers.
Old 29-08-2008, 12:34 PM   #19
6,060, Level: 18
My girlfriends Dad is a builder and so did us a good deal...I wanted to do it myself but due to recently having a baby it would have taken ages. the room took about 4-5 days to complete including electrics and plastering. The total cost for building/plastering/window/another window blocked etc etc was about Ģ2700. a lot of that was on materials due to the requirement from building regulations. I received full plans approval, although the building inspector still made us change a few details when he visited. The main issue was damp proofing the external walls & floor with Tar paint. Still a little way to go yet but at least we're actually using the room now......
Old 20-10-2008, 8:28 AM   #20
6,060, Level: 18
Terrible Photos I know (LG Secrets are Rubbish), thought i'd just show the finished article which was completed late last night...Will post better photos etc in the gallery later this week.
Building Regs advice - Garage Conversion-lgim0051.jpg   Building Regs advice - Garage Conversion-lgim0052.jpg
