Sheep, follower, clone etc etc
Old 22-04-2008, 1:52 PM   #1
2,310, Level: 11
Points: 2,310, Level: 11 Points: 2,310, Level: 11 Points: 2,310, Level: 11
Thanks: Gave 36, Got 54
After much reading and learning from this forum I finally embarked on my own Snellfish/Groove style project.
I have lived in my house for 6 months. It is a new build (3yrs old) and I felt it was time to personalise it a little bit.
I managed to rope in my Girlfriends Dad for the technical bits of the work (all of it) and we got started on Saturday morning.
We discovered after making about 10 holes in the wall that there were no studs, and plans had to change. Cue Polyfiller and a trip to screwfix for me to get some different fixings.
After wasting about the first 3 hours, with the end result being lots of unnecessary holes and no fixings, we finally started making some progress.
Note the filler in between the tv mount batons
So towards the middle of the afternoon the frame was almost complete.
The space next to the socket on the bottom right is to fit a spur double gang socket before fitting the MDF.
Next was fitting the tv mount to the wall batons. This was just to give added support to the structure. Ideally I would have mounted direct to the wall but the lack os studs meant this was probably not the best idea.
We were both confident that this would provide more than ample support to hold the weight of the tv.
Once we had called it a day for the building, I went ahead and properly tested the mount, and added the rope light..
The next day came and I started by carefully preparing for the spur socket. Unfortunately, there was blobs of concrete and plaster where the socket was meant to go and we would have spent all day just working on this, so I decided to use 2 * 6 way extensions from the existing socket and not bother adding more. Cue more filler..
Before adding the MDF we chiselled out a cable run for the tv wires to exit nicely.
Next we cut the MDF panels to size. Used 12mm mdf.
We soon realised the MDF was going to restrict access to the sockets, so took a chisel to the panel to reduce the thickness at this point, allowing the 2 sockets to be able to be (just) unplugged and plugged in.
You can just see this on the image above.
The MDF was quickly mounted and the join was surprisingly good
So at this point my help left me to get on with the wiring and plugging in of everything. This took in the region of 2 hours!!
Lots of protection for the new carpet and newly decorated walls, and the first coat of primer went on
some more filling and priming later and making progress
After I was happy with the mdf prep i applied the first coat of Dulux Expresso Shot feature wall paint.
couple of coats later I was ready to add the rope light for behind the tv. I thought this would be a cheap substitute for LEDs, but it doesn't really give a strong effect. I'm undecided as to whether it will stay at the moment.
Got my equipment up and running and this is what we have. I will update with more completed pictures later hopefully.
Many thanks to the people on here who came up with the concept and to Dennis for giving 2 days up to basically build the thing!
Old 22-04-2008, 10:39 PM   #2
Shockabuku's Avatar
21,771, Level: 35
Points: 21,771, Level: 35 Points: 21,771, Level: 35 Points: 21,771, Level: 35
Thanks: Gave 520, Got 163
Re: Sheep, follower, clone etc etc
Great job, looks really tidy
davidegee (23-04-2008)
Old 23-04-2008, 8:35 AM   #3
2,310, Level: 11
here's a couple of completed shots. Please excuse the quality, all the pics have been taken with a phone.
Both rope lights:
Rear rope light only:
Old 23-04-2008, 8:39 AM   #4
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
It looks very smart
Old 23-04-2008, 9:53 AM   #5
2,836, Level: 12
Points: 2,836, Level: 12 Points: 2,836, Level: 12 Points: 2,836, Level: 12
Thanks: Gave 24, Got 26
Hi mate nice job well done.
Old 24-04-2008, 5:04 PM   #6
3,198, Level: 13
Points: 3,198, Level: 13 Points: 3,198, Level: 13 Points: 3,198, Level: 13
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 16, Got 6
Impressive
davidegee (24-04-2008)
Old 24-04-2008, 7:08 PM   #7
SG-22's Avatar
8,503, Level: 22
Points: 8,503, Level: 22 Points: 8,503, Level: 22 Points: 8,503, Level: 22
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 173, Got 220
look great, any day light pics of your kit?
Old 24-04-2008, 8:32 PM   #8
2,310, Level: 11
Thanks for the comments.
I'll get some daytime pics this weekend, once i've had a chance to get the duster out..
Old 27-04-2008, 9:38 PM   #9
2,310, Level: 11
So here are some daylight pics.
The cabinet is an Ikea Stockholm I got from ebay for £41 and proceeded to butcher. I cut the legs down and cut loads of holes in the back for wiring and ventilation.
The wire to the left is the coaxial running to the kitchen tv. It's the only visable wire and it's not permanent.
The right side houses sky plus and a Sony all in one amp (maybe HSS-1100 ir something).
The left hand side houses my HTPC with 1.5tb HDD and HDMI to my TV. Also in there is PS3 and Wii.
The sound is ample for my requirements at the moment and gets turned down the whole time anyway , so anything more would be wasted.
Thats my lot anyway, thanks again to the guys here.
Old 28-04-2008, 8:30 AM   #10
Kenny Glasgow's Avatar
12,077, Level: 26
Points: 12,077, Level: 26 Points: 12,077, Level: 26 Points: 12,077, Level: 26
Thanks: Gave 71, Got 228
|Very nice
davidegee (28-04-2008)
Old 01-05-2008, 4:54 PM   #11
groove's Avatar
20,304, Level: 34
Points: 20,304, Level: 34 Points: 20,304, Level: 34 Points: 20,304, Level: 34
Thanks: Gave 93, Got 161
That looks awesome dave...and always good to see the Gunners being shown in the final reveal pics
davidegee (01-05-2008)
Old 01-05-2008, 4:57 PM   #12
8,994, Level: 22
Points: 8,994, Level: 22 Points: 8,994, Level: 22 Points: 8,994, Level: 22
Thanks: Gave 6, Got 162
Great setup,the night shots look
Old 01-05-2008, 6:39 PM   #13
2,310, Level: 11
A visit from the messiah of floating walls huh, i feel blessed
Thanks for popping in, I was considering a shameless bump anyway, so thanks for doing it for me!
Old 01-05-2008, 9:31 PM   #14
3,131, Level: 13
Points: 3,131, Level: 13 Points: 3,131, Level: 13 Points: 3,131, Level: 13
Thanks: Gave 18, Got 11
that looks like a great build. i see you have the pain of the sockets in the same place as mine
davidegee (02-05-2008)
Old 02-05-2008, 7:56 AM   #15
2,310, Level: 11
Thanks for dropping in sworrall. I actually used your thread as a reference during the build, as it provided good detail on suitable fixings etc!
Old 02-05-2008, 6:58 PM   #16
groove's Avatar
20,304, Level: 34
Lol.....one of my mates calls me mr Rope Light now....I really should have taken out shares in TLC !
Old 04-05-2008, 1:21 PM   #17
2,462, Level: 11
Points: 2,462, Level: 11 Points: 2,462, Level: 11 Points: 2,462, Level: 11
Fair play mate, that looks mint!
davidegee (06-05-2008)
Old 04-05-2008, 2:18 PM   #18
8,994, Level: 22
I will finish my post
The night shoots look great
