Eichmann Bullet Plugs with Belden 89259
Old 28-03-2003, 3:58 AM   #1
6,709, Level: 19
Points: 6,709, Level: 19 Points: 6,709, Level: 19 Points: 6,709, Level: 19
Has anyone used the above combo? Any problems?
Im not worried about the cable fitting. Just concerned about how difficult it would be to solder the braid to the return pin.
Old 29-03-2003, 12:41 AM   #2
Illustrious Member
48,568, Level: 53
Points: 48,568, Level: 53 Points: 48,568, Level: 53 Points: 48,568, Level: 53
Thanks: Gave 884, Got 1,285
Treat the Eichmann with 'care'.
