Building speakers from common household items
Contrary to popular belief, it is perfectly possible to build a loudspeaker cabinet that sounds just as good as expensive 'pro' speakers, from simple household items. I will give a brief description of the ones I built.
The speaker chasis themselves were taken from an old Ford Escort. They obviously aren't the original speakers, but some aftermarket subs added by the boy racer scum who previously owned it before crashing it and leaving it by the side of the road. For high frequencies, I purchased a pair of cheap piezo tweeters from Maplin.
For the main part, the cabinet, I have used cardboard boxes. Two cardboard boxes were obtained which are about the correct size for the speakers, and duct tape was used to strengthen them in certain places, mainly the corners and seams. The speakers are mounted inside with superglue and duct tape. One advantage of cardboard is that it is very easy to work with. It is also free.
Of course, a single carboard box isn't going to be solid enough for this purpose, so I went to the local supermarket (full of fat pikey slags with their six squalling brats all sired from different fathers, eeeuuuwwww) and obtained many such boxes. I cut these up into neat squares, and attached them to my speakers using glue and duct tape. The whole cabinets were then wrapped in duct tape.
Any modern speaker design will have ports for bass, and mine are no exception. I cut holes into the front of the cabinets, and then stuck half an empty cling film roll in, using superglue.
To give the speakers a good finish, I sprayed them with black car spray paint. This gives a surprisingly professional looking finish, and they are definitely worthy of my living room.
These speakers sound great. I have a friend who has a pair of B&W 602's, and my speakers are at least as good as those, and only cost me £16 for the tweeters, duct tape and glue. I got the speaker wire out of a builders skip. It just goes to show how people with little common sense get ripped off, when a pair of home built speakers costing £16 turn out better than a pair costing £300+.
I hope this post was informative, I may well offer some more tips in the near future.
