Floating Wall material and planning advice required
Old 01-03-2008, 10:10 AM   #1
4,068, Level: 15
Points: 4,068, Level: 15 Points: 4,068, Level: 15 Points: 4,068, Level: 15
Activity: 2.9%
Activity: 2.9% Activity: 2.9% Activity: 2.9%
Thanks: Gave 68, Got 19
Question Floating Wall material and planning advice required
As title not sure what material would be best to work with, plasterboard or MDF considering I have never worked with either before.
Also not sure wether to suface mount speakers and LCD or to flush mount them.
Any advice/tips very much appreciated.
Kind regards
Nigel.
Old 02-03-2008, 9:20 AM   #2
3,267, Level: 13
Points: 3,267, Level: 13 Points: 3,267, Level: 13 Points: 3,267, Level: 13
Thanks: Gave 3, Got 11
Re: Floating Wall material and planning advice required
hi nigel..have a good look at this thread from the start....very good floating wall thread....
Groove's new lounge with floating wall build
Old 02-03-2008, 10:44 AM   #3
4,068, Level: 15
Activity: 2.9%
It was Grooves excellent setup that inspired me along with elootos false chimney breast.
Idealy I would like a combination of the 2 but as my room is much smaller I am not sure it would work.
Still looking around though for plenty more idea's before I start any work and the Mrs is all for it too so thats a good start
Regards
Nigel.
Old 02-03-2008, 11:20 AM   #4
3,267, Level: 13
Unfortunately my missus wants grooves setup too....but i dont think i am upto the job (
I may be busy.....lol
