After a long time waiting my extension/home cimema room should commence in the next few weeks, I've tried to plan as much as I can but cabling/connections between my components still confuses me.
My sources will be a PS3, DVD (HDMI/COMPONENT), SKYHD, Laptop computer (vga out) and a Squeeze Box 3
Display will be a HD plasma and HD projector.
For the moment I plan to use this in a stereo amp setup, in the future I plan to upgrade to a receiver which can sit along side the stereo amp ( stereo amp driving the front speakers )
Dont think I need the laptop computer to display on the projector, the plasma only will be fine, and for sound the headphone jack / line out will surffice.
I would like to display the PS3/DVD/SKYHD on both plasma and projector.
The Squeeze box is the easy one, that can go direct to the amp.
How would you recommened that I connect this lot up, this is what I am thinking of
For video I was thinking of one of these
http://www.octavainc.com/HDMI%20swit...2_toslink.html
This takes care of the outputting to 2 displays and will take of the PS3/DVD/SKYHD as inputs, then I can have a single vga cable to the plasma for the laptop.
For audio, taking into account currently I'll just have a stereo amp, I could run analogue inputs from all sources PS3/DVD/SKYHD/SB3 to the amp.
Does this sound ok ? Should I consider any alternative methods ?
And have I missed anything ? Let me know if I can provide any more information.
Thanks in advance
Marvin
PS. I haven't mentioned models yet for DVD/Plasma/Projector as I have not yet chosen them, but assume they'll have HDMI/Component and optical digital sound outputs.
