Hi All,
After quite a few years debating the issue, a couple of months ago we finally decided to get on and convert our existing integral garage into a dining room and/or playroom.
Anyhow, as part of the Garage conversion we needed to knock a doorway through into the lounge as the main access route into the 'soon to be' Dining Room. As this was going to create quite a bit of mess and also needed a fair bit of fix-up with plastering, it seemed an ideal time to give the lounge an overhaul and get everything setup exactly as I have wanted for quite some time.
My main bugbear was having to use pipes to hide all the cables below the plasma - this was an ok compromise at the time, but I really wanted everything hidden as I am quite fussy like that!
I did think about doing something in the garage conversion with my AV setup, but this room is really for 'family time' away from the TV for playing/eating. "Away from the TV..." can't believe I just said that!!!
This thread will focus on the lounge element of the work, but if there is enough interest I could also add the pictures from the garage conversion, but this isn't really home cinema related. Let me know if I am wrong!
Anyhow, enough rambling and on with the pictures!!!
This is a picture of the exiting setup. It isn't quite up to date as I now have Sky and also changed the floor standers for some KEF wall mounted speakers. I can't believe I didn't take any pictures before I packed everything away
As part of the work, I also decided to downscale my setup a bit as I really don't get time to appreciate a full separates setup and very rarely get to drive the sound to it's full potential. Based upon this decision, the Denon AVC-A10SE and Denon DVD-3800 (which are both huge!) are going to be replaced with a single Arcam Solo Movie 5.1. I decided to keep my existing KEF speakers and also the DVDO iScan video processor as I couldn't live without this now. The Xbox has also been retired to the loft, soon to be replaced with a PS3, mainly to gain access to Blu-Ray releases. With my daughter, I hardly get time to watch movies, let alone play games!!!
Now would also have been an ideal time to swap out the plasma, but I bought this in the "good old days" when plasmas where 2-3k and doubt I would get very much for it now. With the cost of the garage work and other kit changes, I just couldn't justify this change at the moment and the PWD6 does a really good job when driven at 720P from my HD+. I have a universal bracket mounting, so I am pretty confident I could just lift off the old screen and replace with a new one - well, thats the theory!
Right, I am rambling again
Once the lounge was cleared and the wallpaper stripped, it all looked a bit rubbish.
We were thinking of getting the walls re-plastered as the chap would be in for the garage conversion, but after closer inspection, the walls were actually pretty good, I just needed to scrape off all the old paint. I say "just" it actually took me days and days...not the most existing job in the world, but I am sure it was worth it for a good finish
I managed to grab some old bloke off the street to help with the paint stripping...oh ok, it's my Dad helping me out as usual
My wife has hated the existing wallpaper for years, so it was a relief to get rid of it. We have always liked painted walls, but the existing walls looked awful when we first moved in and stripped the paper so decided to go with wallpaper as a short term measure, "short term" ended up being about 5 years. As we wanted plain painted walls, I knew that I would need to get the walls into a pretty good shape and also make a very good job of finishing any new plaster work after the cable channeling - the pressure was on!
We got bored of stripping old paint, so started with the wall channeling, not that this was much more interesting!
Once everything was channeled we used trunking to provide the conduit for all the necessary cabling. As can be seen from the picture (if you look closely) I had taken quite a bit of time to measure and draw out exactly where the plasma and speakers were going to be. This took me a few hours one night (anal me!
) but I knew it was really important to make sure everything was perfect for the final install. As you will see later, I am really, really glad I took the time to get this right, and it was definitely worth the preparation.
In addition to the cables for the plasma, I decided to move my rear speakers from the back wall to the top/back of the side wall. This was mainly needed as the door for the garage conversion was going to be exactly where my existing rear left speaker was! My existing rears were Mission 78DS's which I got to match my 782 fronts, but as these are now gone, I decided to change these for some discrete Anthony Gallo Micros which could be placed up high in the corners of the room, again for that "clean" look (you will notice a theme developing here
So, more channeling to do!
<to be continued...>
