| Re: Streaming Audio/Video throughout
Hi Steve,
I think there are more guys with specialist advice in the Home Automation subforum or the video streaming one, try posting there maybe.
Particularly with video streamers lots of the guys use a NAS box. In each room, folk seem to tend to use an actual media streamer, the Popcornhour is a current favourite. This is a fairly cost effective way to go. Not sure how you'd access it from a touch panel on the wall though. Wouldn't you need remote amplification from the server to do that? Normally the in-room client streamer feeds onto local amplification in each room (although I'm positive there are solutions to give what you describe).
If you read on the media streamer forum, you'll find that people have not had a lot of success with HTPCs. The latest HD media streamers with the latest chipsets seem to do a much better job, particularly with HD media.
Handy that you're familiar with networks, as this is an issue with media streaming. HD video has a reasonable bandwidth requirement, so while you have the chance put a gigabit ethernet in. This will make sure you don't run into any problems in that respect.
HTH,
MarkP
