Program to model buildings
Old 21-02-2008, 12:25 AM   #1
geniusworkin's Avatar
Thanks: Gave 8, Got 44
hiya guys,
not sure if this was the right section, but ill give it a go anyway. Mods please relocate if necessary.
I'm looking for a program that allows me to model buildings, especially houses and particular rooms. I need it in order to plan where certain components of a network/ av system will sit.
Also, i'd prefer if it were Mac compatible.
Thanks in advance,
gw
Old 21-02-2008, 1:05 AM   #2
Re: Program to model buildings
p.s. i've tried, sketchup. Its good, but I'd prefer templates of houses, apartments where I can edit rooms easily.
gw
Old 21-02-2008, 5:54 AM   #3
8,995, Level: 22
Points: 8,995, Level: 22 Points: 8,995, Level: 22 Points: 8,995, Level: 22
Thanks: Gave 6, Got 162
Autocad ?
Old 21-02-2008, 7:56 AM   #4
suniil's Avatar
22,701, Level: 36
Points: 22,701, Level: 36 Points: 22,701, Level: 36 Points: 22,701, Level: 36
Thanks: Gave 836, Got 385
Google sketchup - seconded.
gw
Old 21-02-2008, 7:59 AM   #5
Sofa-loafer's Avatar
5,363, Level: 17
Points: 5,363, Level: 17 Points: 5,363, Level: 17 Points: 5,363, Level: 17
Thanks: Gave 49, Got 61
You need Vectorworks... 3D CAD modelling systems like SolidWorks, SolidEdge, Pro-Engineer are all simple to use once you grasp the concept. However, I believe these will only work on XP. Adobe Illustrator is simple but not as simple as a pencil and paper. Scan that into your pc.
Search for freeware architectural software... not sure about MAC versions though.
Old 21-02-2008, 10:17 AM   #6
Toonaroond's Avatar
4,999, Level: 16
Points: 4,999, Level: 16 Points: 4,999, Level: 16 Points: 4,999, Level: 16
Thanks: Gave 88, Got 34
What about Sweet Home 3D? its really easy to use....and free
Shockabuku (21-02-2008)
Old 21-02-2008, 12:14 PM   #7
1,829, Level: 9
Points: 1,829, Level: 9 Points: 1,829, Level: 9 Points: 1,829, Level: 9
Thanks: Gave 1, Got 0
Microsoft Visio works quiet well if you want something simple and it has templates and I believe more are available to download.
I've used it to model the factory where I work and everyone was happy with the results.
Old 21-02-2008, 4:09 PM   #8
8,995, Level: 22
I used Microsoft Visio to redesign our workshop space
Worked well
Old 21-02-2008, 9:30 PM   #9
3,387, Level: 13
Points: 3,387, Level: 13 Points: 3,387, Level: 13 Points: 3,387, Level: 13
Thanks: Gave 4, Got 11
I'd vote for Sketchup too. I use it everyday. Some examples of what it can achieve
Floor Plans
Old 21-02-2008, 9:37 PM   #10
Floor Plans
how ???
they're amazing.
gw
Old 22-02-2008, 5:40 AM   #11
8,995, Level: 22
Just had a play around with Google sketchup 6,great program
Old 22-02-2008, 9:40 AM   #12
Owen824's Avatar
13,132, Level: 27
Points: 13,132, Level: 27 Points: 13,132, Level: 27 Points: 13,132, Level: 27
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 185, Got 192
glad i cam across this thread. going to give the sketchup a shot. might help me get ideas for my project.
Old 22-02-2008, 4:18 PM   #13
2,284, Level: 11
Points: 2,284, Level: 11 Points: 2,284, Level: 11 Points: 2,284, Level: 11
Thanks: Gave 2, Got 5
chief architect
or
dreamhome designer
both are good.
Old 23-02-2008, 7:54 PM   #14
1,742, Level: 9
Points: 1,742, Level: 9 Points: 1,742, Level: 9 Points: 1,742, Level: 9
Thanks: Gave 11, Got 7
Archicad can be quite good, I use it on my architecture course quite a lot and not too difficult.
Old 24-02-2008, 12:31 AM   #15
cheers guys,
keep em coming.
