Concrete Ceiling - types of fittings?
Old 20-02-2008, 4:24 PM   #1
sapper's Avatar
20,094, Level: 34
Points: 20,094, Level: 34 Points: 20,094, Level: 34 Points: 20,094, Level: 34
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 432, Got 139
Question Concrete Ceiling - types of fittings?
Hi all,
Living in an ex council flat, the ceiling is a rather large slab of concrete...
I am assuming that to secure both the scren and projector mount to the ceiling, I need to use some thing like these Raw-bolts?
The projector is heavy-ish at 11.5 kg or so.
Adrian
Old 20-02-2008, 4:30 PM   #2
thecornfords@go's Avatar
3,046, Level: 12
Points: 3,046, Level: 12 Points: 3,046, Level: 12 Points: 3,046, Level: 12
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 6, Got 11
Re: Concrete Ceiling - types of fittings?
these would do the job for sure. iv'e used them in the past and i could hang myself of 4 of them and im 16 stone. just make sure you drill the holes square and not to baggy!
sapper (20-02-2008)
