Chasing cables in exposed brick...
Old 19-02-2008, 9:47 AM   #1
2,625, Level: 11
Points: 2,625, Level: 11 Points: 2,625, Level: 11 Points: 2,625, Level: 11
We have placed an offer on a new house, it needs some work and a general tidy up, I am planning if all goes well to mount a tv above the fire place, the walls at present are exposed brick;
we have a builder friend who is going to plaster over the brick for us, however i want to chase the cables into the wall first, how will i do this with the exposed brick??
Old 19-02-2008, 10:46 AM   #2
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Re: Chasing cables in exposed brick...
I don`t know whats behind the brick but wouldn`t it be better to removed it and gain space as well
Old 19-02-2008, 10:56 AM   #3
paulyoung666's Avatar
5,686, Level: 17
Points: 5,686, Level: 17 Points: 5,686, Level: 17 Points: 5,686, Level: 17
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 266, Got 381
just cut a groove into the face as you would with plaster etc
Old 19-02-2008, 11:17 AM   #4
2,625, Level: 11
the sections either side of the fireplace are 1x brick depth, and so I can rip these out no problem and make good the wall behind, however the fire place wall is quite deep and I am unsure on what is behind, so the plan was just to skim over this. as what ever is behind this would prob need skiming anyway so possible save a bit of time??
Old 19-02-2008, 11:18 AM   #5
2,625, Level: 11
cool.. whats the best tool to use for this?
Old 19-02-2008, 1:57 PM   #6
Bacus's Avatar
7,446, Level: 20
Points: 7,446, Level: 20 Points: 7,446, Level: 20 Points: 7,446, Level: 20
Thanks: Gave 486, Got 342
you could go and hire a wall chaser from your local hire shop
OR
The old way of a big club hammer and bolster
Old 19-02-2008, 2:23 PM   #7
2,564, Level: 11
Points: 2,564, Level: 11 Points: 2,564, Level: 11 Points: 2,564, Level: 11
Thanks: Gave 1, Got 4
Be warned though, a wall chaser creates unbelievable amounts of dust.
But it is much quicker than a hammer and chisel.
