Ok i have had lots of inspiration from these forums and alot of good ideas so i thought " i want one of them " so from buying the house about 5 months ago here is where i am upto today.
Below is a few pictures of before and after of the first stage of my install.
Stage 1 was to get the loft hatch made bigger and the youngman ladders fixed up ,and also make the landing 2 ft bigger so you don't struggle to get onto the ladders.
Just to let you know i had all the plaster removed from every wall in the house and also all false ceilings put up ....what a mess !!!! but got there in the end .
Inside the loft
On the Landing before any Plaster is Removed & New Hatch Fitted
After Plaster has all been Removed
After the landing floor has been altered 18" Approx for better access to the ladders
Fitting the new Velux Window
Strengthening the Loft floor with some sturdy timbers from the center Supporting Wall
Temp insulation in loft space to keep some heat in untill i install the Kingspan or Rockwool Undecided as of yet which would be best.
2 Months Later !! Upstairs is nr finished after all the Plasterboard was fitted and a new Spindles/Post & Rails.door casing,doors etc etc
All of the flooring has now been fitted into the loft along with a feed for a radiator and the electrics.
Plan "
B" now is to get the walls studded or plastered not sure what yet and get the roof insulated & Sondproofing as much as possible.
I have decided i would like to wood clad the loft ceiling and maybe plaster the walls , i will also be building some shelfs and cupboards up there to accomodate my equiptment and Pc and was thinking of some type of Pelmet to cover the PJ Screen when not in use.
I have been thinking of seating and wondered what settee i can fit up or would it have to be one of them frame type ones you have to build yourself .
I will try to update this thread as i go along so watch this space .
