You don't need planning permission, it's building regs approval. (You sometimes need planning permission for a dormer window if you're fitting one, but usually only if it's on the front elevation).
i opted for 4x2 and now my floor is solid with no give whats so ever
- it all depends on the span really. The longer the distance between the supports, the greater the deflection for a given joist size. 4x2 may work for you - when I had my loft converted, it had to be 8x2!! There will probably be a difference though in what will flex when you walk on it, and meeting the loading requirements for habitable rooms as defined in building regs.
Plenty of people convert lofts for "storage" use. Obviously it can't be classed as a room as such if you come to sell the house. Planning permission not required. If you want it to be classed as a "habitable" room, then building regs apply, otherwise it's a storage room. If you don't go for building regs, then strictly speaking you are breaking regulations (along with many many others throughout the land!), whether you wish to sell or not. Change of use is the issue, even if it's for your own use.
The room will be non habitable and will be basically used as TV/office room
- TV/office isn't non-habitable. That counts as change of use, so building regs would apply. Non-habitable means storage, you don't have to sleep in it for it to become a habitable room.
Building regs covers a multitude of things -
Floor joist loadings, as discussed
Fire protected access (self-closing fire doors on all doors to the stairwell)
Linked smoke alarms on all floors (you're increasing the number of floors in effect).
Staircase to specific gradient, tread size and headroom dimensions
Sound inhibition to floor below, and to neighbours via partition walls
Thermal insulation and ventilation for the roof.
Part P regs for the wiring
Mainly safety stuff, hence my recommendation that even if you don't go for building regs, you should consider the linked smoke alarms for your own safety.
Not trying to put you off, it's up to you if you go for regs or not, as that makes it a far, far bigger (and more expensive!) project. Get the floor right though, as it's structurally important, and peace of mind is worth a bit of money IMHO.
HTH,
MarkP
