Aesthetically pleasing trunking ?
Old 04-02-2008, 5:03 PM   #1
6,434, Level: 19
Points: 6,434, Level: 19 Points: 6,434, Level: 19 Points: 6,434, Level: 19
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 58, Got 75
Still planning the lounge and am thinking of some trunking going up the corners of my recess.
Does anyone know where I can get something that looks decent... I've seen some of the 'silver' which costs a ridicoulous £15 a metre !
Ideally I would love to find some that can be mounted in the corner rather than the plain boxed shaped ones that you can get these days
Any help would be greatly appreciated.
Old 04-02-2008, 5:07 PM   #2
2,284, Level: 11
Points: 2,284, Level: 11 Points: 2,284, Level: 11 Points: 2,284, Level: 11
Thanks: Gave 2, Got 5
Re: Aesthetically pleasing trunking ?
http://www.plasticsuppliers.co.uk/ambassador.html
http://www.tlc-direct.co.uk/Main_Ind...dex/index.html
http://www.kentselfbuild.com/Sovereign2Part.html
http://www.cablemanstore.co.uk/erol.html#38752X0
Subliminal Aura (04-02-2008)
Old 04-02-2008, 5:15 PM   #3
6,434, Level: 19
Activity: 0.8%
Obvioiusly someone who knows how to use google better than me.. Thanks mate.
Maybe
http://www.tlc-direct.co.uk/Products/DL2D30QSA.html
And some silver spraypaint will do the trick
Old 17-02-2008, 7:47 PM   #4
2,667, Level: 12
Points: 2,667, Level: 12 Points: 2,667, Level: 12 Points: 2,667, Level: 12
Thanks: Gave 2, Got 0
When I fixed my Samsung LCD to the wall, I used a piece of 22mm plastic waste pipe, sliced down the back, fed the cables in and then covered the thing with Chrome Fablon sticky plastic - It looks cool!! Cost about a fiver!!
