Building a Fake wall
Old 21-01-2008, 12:46 PM   #1
3,939, Level: 14
Points: 3,939, Level: 14 Points: 3,939, Level: 14 Points: 3,939, Level: 14
Thanks: Gave 1, Got 10
Am having a fake wall built later this week, 8ft x 8ft and a couple of inches deep.
Can anyone tell me the do's and dont's of building a fake wall so i can pass this onto the builder?
I'll be mounting a Pioneer 5080D and M&K Xenons.
What cable feeds should i be feeding from the TV to the amp? I was thinking 2 x HDMI cables (1 from amp and 1 from the Sky HD box) and the power lead to the plasma. Anything else?
Old 21-01-2008, 1:01 PM   #2
Conspicuous Member
nheather's Avatar
17,661, Level: 32
Points: 17,661, Level: 32 Points: 17,661, Level: 32 Points: 17,661, Level: 32
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 595, Got 1,168
Re: Building a Fake wall
What do you mean by a fake wall? - thought you meant a dry partition at first but then you mention that it's only a couple of inches thick.
Cheers,
Nigel
Old 21-01-2008, 2:46 PM   #3
Franco50's Avatar
4,236, Level: 15
Points: 4,236, Level: 15 Points: 4,236, Level: 15 Points: 4,236, Level: 15
Thanks: Gave 46, Got 40
I'm assuming he means a 'floating wall' as per some of the projects in this forum?
