Isopon P38
Old 11-11-2007, 3:54 PM   #1
8,416, Level: 21
Points: 8,416, Level: 21 Points: 8,416, Level: 21 Points: 8,416, Level: 21
Thanks: Gave 50, Got 16
Isopon P38
I'm visiting the UK this week and I'm trying to arrange all the bits and bobs that I will need for my home cinema construction.
One of the things that has been recommended in various threads is the use of David's Isopon P38 filler for the purpose of filling MDF joins.
I've seen a few (small) online shops that sell it, as well as (of course) ebay.
However, I'm not sure
a) How much I'll need for an MDF cinema project? (I intend to use MDF around the ceiling to create a dropped ceiling border, so there will be plenty of joins to fill - room is 4.5m x 2.5m)
b) Whether I need to buy separate hardner, or does it usually come with everything required?
I was thinking of getting a 600ml container of the stuff:
http://www.wilcodirect.co.uk/catalog...oducts_id=1580
but then I noticed that some other sites sell P38 hardner too:
http://www.motortraders.co.uk/xcart/..._Hardener.html
Can anybody tell me what I need? Is 600ml plenty enough?
Also, where might I get this stuff from in a bricks & mortar store in the UK? Would halfords sell the stuff perhaps?
Many thanks!
Old 11-11-2007, 4:28 PM   #2
suniil's Avatar
22,696, Level: 36
Points: 22,696, Level: 36 Points: 22,696, Level: 36 Points: 22,696, Level: 36
Thanks: Gave 836, Got 385
Re: Isopon P38
yes they have, i got it from them. I cannot comment on how much you require, but you may have to give some room for wastage! i wasted a 25% as mixed with lot of hardner initially
Old 12-11-2007, 9:11 AM   #3
8,416, Level: 21
Re: Isopon P38
Thanks Suniil.
Do you buy the hardner separately, or does it come with it?
I'm still not sure whether I should buy this stuff online or risk it in Halfords (Bath branch, the one in the middle of town and it doesn't look that big)...
How much did you buy for your project? (which is looking great BTW!)
Old 12-11-2007, 9:14 AM   #4
8,416, Level: 21
Re: Isopon P38
Also, there seem to be two different numbers, i.e #1 and #2
ISOPON P38 No.1 Paste - 600ml Tin
ISOPON P38 No.2 Paste - 1.2 Litre Tin
Is one the hardner?
Sorry for the stupid questions - it is quite hard buying this stuff blind when you've never used it before
Old 12-11-2007, 9:32 AM   #5
suniil's Avatar
22,696, Level: 36
Re: Isopon P38
"P38 easy sand" - that's the product name. I bought 250ml pack, it comes with hardner as well. half of the pack was good enough to finish 12 feet (length) , 1.5cm (width) finish
HTH
Is one the hardner?
Mr. Wilby (12-11-2007)
Old 18-08-2008, 7:43 PM   #6
av addict's Avatar
14,084, Level: 28
Points: 14,084, Level: 28 Points: 14,084, Level: 28 Points: 14,084, Level: 28
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 90, Got 85
Re: Isopon P38
is this the stuff for sealing MDF joins,on here it says this is for repairs to metal
cheers
http://www.halfords.com/webapp/wcs/s...0151&langId=-1
