| Re: Using tape to hide micro speaker cable
No, the channels are just standard electricians capping in steel, I have looked at channels before, but in reality as long as you think about the job there should be no reason to add cables later, how often will you upgrade over next 5 years? By then your room will need re-decorating anyway! Just add spare HDMI, couple of cat5 for general use and maybe optical. Also the channels would have to be fairly large rather than just the top layer of plaster and board which would add a reasonable amount of time and mess.
Another pic of cables running across below, just try and run cables according to part P rules, its good practice.
I was an evo man, but got rid as now doing new business and want to move house. Now have Transit Connect! But will return to the evo once funds allow!
Dupe…
