House options - bare garage or narrowish bedroom
Old 05-11-2007, 10:52 PM   #1
3,227, Level: 13
Points: 3,227, Level: 13 Points: 3,227, Level: 13 Points: 3,227, Level: 13
Thanks: Gave 15, Got 28
Hi all
I'm looking at buying a house at the moment, mines sold so need to get somewhere sorted.
One I've looked at has an attached Garage(bare brick) of 36' x 8'11" although the large boiler is at the window end so would need to leave a utility area.
The other house has a finished bedroom of 20' x 7'7" narrowing to 5' 5"
this is above the Garage, I think it ends up being 15' x 7'7" effective
Although I've had a look around on the forum would I end up with a bigger cinema in the house with the large Garage, no I'm not stupid I know is longerbut I would ideally want to leave room for the car aswell.
I'm planning on using my CRT PJ and 92" 16:9 screen....
comment and thoughts welcome...
Old 05-11-2007, 11:07 PM   #2
4,510, Level: 15
Points: 4,510, Level: 15 Points: 4,510, Level: 15 Points: 4,510, Level: 15
Thanks: Gave 16, Got 146
Re: House options - bare garage or narrowish bedroom
Have a drive in cinema??
Seriously, it depends on the houses. How much use your intended room would get. How many people. and many many other questions..
Old 05-11-2007, 11:13 PM   #3
3,227, Level: 13
Okay both houses are detached and the one with the large Garage also has a great lounge of 25' x 13' 6", open plan though to upstairs
I guess it won't be used everyday and most likely no more than 5 people at any one time.
I'm also currently single so....
Old 06-11-2007, 9:48 AM   #4
4,510, Level: 15
Go with that one! Sounds to me you like it more already!
Old 06-11-2007, 12:15 PM   #5
3,810, Level: 14
Points: 3,810, Level: 14 Points: 3,810, Level: 14 Points: 3,810, Level: 14
Thanks: Gave 4, Got 8
Go with the large garage - it's wider (even taking into account a further reduction by studding out the walls). You'll want as much width as possible for better separation across the front speakers.
