Plasma Installation - what height?
Old 05-11-2007, 1:23 PM   #1
4,510, Level: 15
Points: 4,510, Level: 15 Points: 4,510, Level: 15 Points: 4,510, Level: 15
Thanks: Gave 7, Got 5
Hi All
Spent some time reading through the posts - very informative.
I'm planning to wall mount a 50" Pioneer Plasma onto a dot and dab dry-lined thermalite wall.
My question isn't (yet!) how do I do it? I've already mounted a 32" LCD in the "playroom" using the Fischer resin stuff and threaded bolts (and it's still up!).
No, my question is how high should the screen be off the floor to make comfortable viewing and to ensure the quality of the the display is optimal? Obviously, ALL the viewing will be from the comfort of the sofa, so should the screen be mounted at the same height as a conventional TV i.e. pretty much eye level?
Thanks in advance!
John
Old 05-11-2007, 3:07 PM   #2
6,276, Level: 18
Points: 6,276, Level: 18 Points: 6,276, Level: 18 Points: 6,276, Level: 18
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 114, Got 61
Re: Plasma Installation - what height?
Most folk prefer the center of the panel at eye level, some prefer a slightly higher fixing using a tilting bracket.
Whatever suits you sir is the answer........
Old 06-11-2007, 2:02 PM   #3
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
ball park of 1200mm from floor to bottom of screen
Old 06-11-2007, 3:32 PM   #4
9,165, Level: 22
Points: 9,165, Level: 22 Points: 9,165, Level: 22 Points: 9,165, Level: 22
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 217, Got 360
My 40 inch is around a metre to the bottom of the screen, have always found 1.2 to be too high!
Old 06-11-2007, 3:41 PM   #5
Assured Advertiser
63,997, Level: 61
me too sean but most people find that way too low mine is actualy 880mm from the floor but thats too low for most
Old 19-11-2007, 8:55 PM   #6
4,893, Level: 16
Points: 4,893, Level: 16 Points: 4,893, Level: 16 Points: 4,893, Level: 16
Thanks: Gave 5, Got 42
Doesn't it depend on the size of your screen?
103" - 30cm
80" - 35cm
71" -40cm
65" - 50cm
63" -55cm
60" -60cm
50" -100cm
42" -110cm
37" -120cm
ish...
Old 19-11-2007, 11:55 PM   #7
Assured Advertiser
63,997, Level: 61
103" - 30cm
80" - 35cm
71" -40cm
65" - 50cm
63" -55cm
60" -60cm
50" -100cm
42" -110cm
37" -120cm
ish...
i like the idea cyril it also dpends on seating height and distance to screen othewise what would you do when you got a 250" screen?
Old 20-11-2007, 12:35 AM   #8
4,893, Level: 16
Assuming standard sofas, standard home cinema size (5m to 6m?), flat horizontal floor I guess
250"+ - Zero to negative 50cm
200" - Zero to negative 20 cm
150" - 0cm
i.e. you might need to build a sloping floor from your sofa otherwise the 250" screen's centre might be too high
http://www.avsforum.com/avs-vb/showthread.php?t=505237
