Groove,You are an inspiration,Here's my version.
Old 21-10-2007, 2:51 AM   #1
Mark-UK
Posts: n/a
Hi All,
For those of you,like myself,who have been recently following "Grooves" Foating plasma wall thread Groove's new lounge with floating wall build,
here is my current set of progress pictures to inspire those of you that are thinking of doing the same.
I had wanted to upgrade my current set-up for some time now and had the idea of mounting a plasma on a floating wall.
I had already planned what plasma that i wanted to buy after alot of research in the magazines and also here in the Pioneer 8G owners thread.
Then I found groove's thread here and WOW.......like it.....like it alot.
So groove,here's to you fella,you are an inspiration my friend.
So,on to the pictures
I had placed this paper cut out of the telly on the wall so the missus could get used to the idea of having a huge screen on the wall.
Eventually she gave in
[IMG]
[/IMG]
A couple of trips to wickes for materials,then time for the all important health and safety briefing with the site forman,my 4yr old,who is not taking it seriosly at all LOL.[IMG]
[/IMG]
With some help,and the one and only time I will ever let the Littl'n draw on the walls we planned it out.
[IMG]
[IMG]
Frame on the wall.
[IMG]
[/IMG]
Frame covered with MDF,Tilting bracket in place.
[IMG]
[/IMG]
Rope light in place behind board to check wall wash[IMG]
[/IMG]
Decided to cover the panel rather than paint it,so fabric stretched over and secured.
[IMG]
[/IMG]
Last picture,and currently my favourite one.
[IMG]
[/IMG]
Following Groove's build on the forum,I have got some design tips,and inspiration to carry out my own build.
So Groove, I salute you sir.
I hope you like the progress so far,I can't wait to get it finished.
I will post up some more pictures when the build is complete.
All the best
Mark.
Old 21-10-2007, 7:39 AM   #2
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Re: Groove,You are an inspiration,Here's my version.
Hi Mark
your an early riser mate or a later stayer upperer. Its great to see someone making good use of the work done on the threads. You seem to know what your doing and I like the fabric idea as well. If you`d done it white you could have used it as a screen for the forthcoming pj
Anyway good luck . post pics as and when
cheers Allan
PS. I CAN`T WAIT FOR SOMEONE TO COPY WHAT WE`VE BEEN UP TO
Mark-UK (28-10-2007)
Old 21-10-2007, 2:47 PM   #3
3,387, Level: 13
Points: 3,387, Level: 13 Points: 3,387, Level: 13 Points: 3,387, Level: 13
Thanks: Gave 4, Got 11
i have one thing to say........................nice calender
Old 21-10-2007, 4:23 PM   #4
thegavsters
Posts: n/a
I was going to say the exact same thing
Old 21-10-2007, 4:51 PM   #5
lone ranger's Avatar
7,995, Level: 21
Points: 7,995, Level: 21 Points: 7,995, Level: 21 Points: 7,995, Level: 21
Thanks: Gave 0, Got 37
i like the idea of covering the boarding in black cloth,good thinking and will help overall picture experience no end.shaping up nicely.
Old 25-10-2007, 2:39 AM   #6
6,402, Level: 19
Points: 6,402, Level: 19 Points: 6,402, Level: 19 Points: 6,402, Level: 19
Thanks: Gave 2, Got 0
Nice one Mark, I like it a lot!
Looking forward to the next set of pics hopefully with Kef's on the walls :-)
cheers
Old 25-10-2007, 7:47 AM   #7
Location: Perth, Western Australia (Originally Ireland)
11,024, Level: 25
Points: 11,024, Level: 25 Points: 11,024, Level: 25 Points: 11,024, Level: 25
Thanks: Gave 84, Got 82
What type of cloth material are you using?
Old 26-10-2007, 2:30 PM   #8
groove's Avatar
20,304, Level: 34
Points: 20,304, Level: 34 Points: 20,304, Level: 34 Points: 20,304, Level: 34
Thanks: Gave 93, Got 161
Mark.........awesome work fella.
Glad i could be of a little inspiration to someone....i really like what you've done there, the cloth is a stroke of genius........the sanding of the joins and screw holes on the MDF panels were things i still have nightmares about !
Ill be following your progress now ive found your thread with great interest and a touch of pride
Keep the updates coming mate.......cant wait to see more.
G
Old 28-10-2007, 2:13 PM   #9
Mark-UK
Posts: n/a
Oh Yeh,I meant to resize that picture before posting
Old 28-10-2007, 2:16 PM   #10
Mark-UK
Posts: n/a
Hi Markie Boy,The material is a cotton and lycra mix 80/20%
Old 28-10-2007, 2:39 PM   #11
Mark-UK
Posts: n/a
G
Thank's Groove,
I came up with the idea of covering the panel with material rather than fill and paint due to the fact that i work with filler on a daily basis in my work.
I wanted to get the job done reasonably quickly so cheated a bit with the use of material.
Here is a pictorial update for you guys.
Have got a bit of cable tidying to do,but I'm nearly there.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
And finally I can have a seat,kick back and relax
[IMG]
[/IMG]
Thanks for the endorsment Groove,I hope that you like what ive done.
Thankyou to all of you who have taken the time to post replies and P.M me with questions,apologies if it has taken a while to get back to you all.
Also a big thankyou to Bumtious and others from the Pioneer 8G owners thread for the settings.
Cheers all
Mark.
