External TV Aerial Splitter
Old 20-10-2007, 5:54 PM   #1
2,792, Level: 12
Points: 2,792, Level: 12 Points: 2,792, Level: 12 Points: 2,792, Level: 12
Thanks: Gave 1, Got 8
Does anyone have any ideas what the best way to split a TV aerial is outside the house?
All the normal solutions seem to be for internal applications but I need to do it outside to save me having to run a new cable from the aerial on the roof.
Old 20-10-2007, 10:26 PM   #2
diesel's Avatar
7,195, Level: 20
Points: 7,195, Level: 20 Points: 7,195, Level: 20 Points: 7,195, Level: 20
Thanks: Gave 262, Got 59
Re: External TV Aerial Splitter
I'm not sure they do a fitting thats designed to be waterproof, so thinking laterally; could you not buy a small waterproof enclosure and make the connections in that. It would be quite discreet and would save you running the new cable.
I think they are about a tenner for the small enclosures.
HTH
Andy
Old 20-10-2007, 10:38 PM   #3
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Andy`s got the right idea but the wrong price, if you have an Eyre & Elliston near you or any decent electrical supplier pay no more than 2 quid for a water proof enclosure. Mine in the sump which is 10x8 was under £4 so with a 2 male/female connector you should do the job for under a fiver.
Allan
Old 21-10-2007, 10:50 AM   #4
2,792, Level: 12
Thats exactly the thought I had but was amazed there wasnt a retail solution
Ill go with that
Old 21-10-2007, 12:52 PM   #5
nickp8's Avatar
9,829, Level: 23
Points: 9,829, Level: 23 Points: 9,829, Level: 23 Points: 9,829, Level: 23
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 78, Got 154
Use a mashead amp with multiple outputs.
http://www.satcure.co.uk/accs/page11c.htm
Old 21-10-2007, 6:14 PM   #6
Tesla's Avatar
6,657, Level: 19
Points: 6,657, Level: 19 Points: 6,657, Level: 19 Points: 6,657, Level: 19
Thanks: Gave 21, Got 35
You can get splitters housed in waterproof cases. Retail product.
Old 22-10-2007, 1:48 PM   #7
3,169, Level: 13
Points: 3,169, Level: 13 Points: 3,169, Level: 13 Points: 3,169, Level: 13
Thanks: Gave 2, Got 0
What about something like this....
http://www.nextag.co.uk/Outdoor-TV-A...uk/prices-html
we had something similar at a house we had some years ago.
Mick.
