Wall Mounted TV & Storage Design Ideas
Old 15-10-2007, 3:01 PM   #1
eireann10's Avatar
5,609, Level: 17
Points: 5,609, Level: 17 Points: 5,609, Level: 17 Points: 5,609, Level: 17
Thanks: Gave 235, Got 105
Cool Wall Mounted TV & Storage Design Ideas
Hi guys
i am re-doing my room and need a little design help.
it is a square room and the TV will be put in the corner. i am putting a stud wall so the TV will be mounted on this wall pointing across to the opposite corner.
i will have a 42" LCD TV (not sure which one yet - any ideas welcome). but mainly i dont want a cabinet in the room, i would prefer to have built in storage for my DVD, PS3 etc below the TV and also a compartment for power, Phone line etc. i have the cables going down the back of the stud wall, power sockets etc will be down low as said.
Has anybody done this, any design ideas would be welcome, or even pictures would be even better.
thanks in advance.
Old 16-10-2007, 8:54 AM   #2
eireann10's Avatar
5,609, Level: 17
Re: Wall Mounted TV & Storage Design Ideas
anyabody even point me in the right direction of a gallery or some pics of recessed cabinets below a wall mounted TV
really need help here and not sure what design would be best
the stud wall will be anything up to 2 metres wide and 2.5m high
Old 16-10-2007, 9:47 AM   #3
Franco50's Avatar
4,236, Level: 15
Points: 4,236, Level: 15 Points: 4,236, Level: 15 Points: 4,236, Level: 15
Thanks: Gave 46, Got 40
Not sure if this is similar to what you have in mind ...........
my lounge with progress pix
Old 16-10-2007, 9:59 AM   #4
eireann10's Avatar
5,609, Level: 17
yep Franco thanks, this is exactly what i am doing, tis will be a great help
been going through this forum for the past two days (at work ) and havent came up with anything.
