Black and White Bedroom
Old 04-10-2007, 4:29 PM   #1
3,964, Level: 14
Points: 3,964, Level: 14 Points: 3,964, Level: 14 Points: 3,964, Level: 14
Thanks: Gave 3, Got 0
I am intending to redo the whole bedroom with a professional yet plain theme - i was thinking White walls with the 42 "WLCD mounted and a low table beneath with all av equipment stored on it
i want to know would a white wall and black carpet look silly - please speak the truth i wont be offended genuinely looking for advice - i can post pics of the room at present with dimensions for the best location if this helps anyone
thanks in advance
Old 04-10-2007, 6:28 PM   #2
peterpatch's Avatar
2,642, Level: 11
Points: 2,642, Level: 11 Points: 2,642, Level: 11 Points: 2,642, Level: 11
Thanks: Gave 66, Got 13
Re: Black and White Bedroom
Black carpet will look good imo, but you will be fed up vacuuming all the time. I have very dark green carpet which shows every speck of dust.
Old 05-10-2007, 6:53 AM   #3
THERINGMASTA's Avatar
4,635, Level: 16
Points: 4,635, Level: 16 Points: 4,635, Level: 16 Points: 4,635, Level: 16
Thanks: Gave 4, Got 2
I own a house with my best mate; his room is black and white and it looks the b*ll*cks.
He has black and white floral wallpaper as a 'feature' wall behind his bed, the rest of the walls are white, as well as the wooden floor is painted a washy white (so the grain is still visible), then he has a black bed with white covers, and then a couple of deep red items i.e. a red throw for his bed and a red rug. But all together it looks pretty damned good and i would recommend.
Old 05-10-2007, 10:04 AM   #4
Franco50's Avatar
4,236, Level: 15
Points: 4,236, Level: 15 Points: 4,236, Level: 15 Points: 4,236, Level: 15
Thanks: Gave 46, Got 40
Same here. I have a navy blue carpet in my lounge and it shows up everything!
Old 05-10-2007, 10:38 AM   #5
3,810, Level: 14
Points: 3,810, Level: 14 Points: 3,810, Level: 14 Points: 3,810, Level: 14
Thanks: Gave 4, Got 8
Black and white
White walls will be fine, but I agree with the others about darker carpets showing up everything.
What about going a few shades lighter? I know you're venturing into grey territory, but it might work particularly if you're using black table and black boxes?
