Which Bracket ???
Old 19-09-2007, 9:03 PM   #1
ALASTAIR888
Posts: n/a
Which Bracket ???
I Own A 42" Plasma And Are Just Installing It Into My Chimney Breast. Can Anyone Recommend A Bracket Thats Cheap?? Would It Be Possible To Install A Cheap Bracket With Some Fischer Fixings Instead Of The Plastic Raw Plugs That Are Supplied. How Much Should I Really Be Investing Into The Bracket ???
I Also Like The Idea Of Installing A Rear Lighting System Around The Back Of The Plasma. Can Anyone Advise Me Of Which Kind Are Best And Are There Any Problems With Overheating Etc.
