LCD mount on TV - cables?
Old 09-06-2007, 10:40 PM   #1
Thanks: Gave 5, Got 1
Hello everyone!
Please bear with me - I did a search for this, but would like some feedback on my situation.
I want to mount a LCD tv on my chimney breast. I got a quote from a company - £260! To chase in the wires as well.
I was wondering how hard it is to chase wires if I hired the correct tools. Also, how safe is it to do this (into a brick) chimney breast. Would I make my house fall down?
I think I'll need one or two HDMI cables, power, aerial, maybe a VGA cable. Would I be able to put in trunking and add more cables later - would this work around a 90 degree bend??? i.e. around the chimney breast.
Thanks!
AB
Old 12-06-2007, 8:41 PM   #2
2,979, Level: 12
Points: 2,979, Level: 12 Points: 2,979, Level: 12 Points: 2,979, Level: 12
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 11, Got 20
Re: LCD mount on TV - cables?
The price depends on the difficulty of the hob.
If you have a new house and the room is a bit of a mess anyway then i'd say do it yourself, but if you have furniture and electronics all in then perhaps the pro's could do a cleaner install.
you only need to chase about 40mm square so i wouldnt worry too much about the house collapsing.
abadr (14-06-2007)
Old 13-06-2007, 12:48 PM   #3
3,602, Level: 14
Points: 3,602, Level: 14 Points: 3,602, Level: 14 Points: 3,602, Level: 14
I'm in the exact same poistion as you.
There's a small alcove between the chimney breast and the wall.
This alcove would be ideal to stick my home cinema / xbox / sky.
So the equipment would be next to the wall mounted TV.
How easy is this to do? Who do you phone to get this done? surely not a plasterer?
I also have the problem of a radiator being under where I want my TV...
How hard is it to move a radiator from one side of the room to the other?
Is it worth it?
Old 14-06-2007, 9:01 PM   #4
Well I looked up a company called 'Master AV services' I think. They do installs like this.
We just bought the place and are decorating - so nothing in the room. Am tempted to do it myself but still unsure!
:S
