help with hardware.
Old 04-06-2007, 4:55 PM   #1
jason g's Avatar
47,873, Level: 53
Points: 47,873, Level: 53 Points: 47,873, Level: 53 Points: 47,873, Level: 53
Activity: 28.0%
Activity: 28.0% Activity: 28.0% Activity: 28.0%
Thanks: Gave 3,615, Got 1,639
Cool help with hardware.
hi, im building some units at the moment and im looking for some certain hinges, they are the ones used on barrister bookcases, i want these for my tv unit im building which i plan to have a front lift up and slide back into the unit above the tv, i cant find any at all ive looked everywhere and the only thing ive seen them on is this barrister bookcase.
does anyone know where i could purchase such an item?
cheers.
Old 04-06-2007, 7:20 PM   #2
louishm's Avatar
4,448, Level: 15
Points: 4,448, Level: 15 Points: 4,448, Level: 15 Points: 4,448, Level: 15
Thanks: Gave 32, Got 54
Re: help with hardware.
sorry mate i cant help you with your hinges as i am too busy laughing at your sig. .
jason g (05-06-2007)
Old 05-06-2007, 1:33 AM   #3
2,258, Level: 11
Points: 2,258, Level: 11 Points: 2,258, Level: 11 Points: 2,258, Level: 11
Thanks: Gave 13, Got 13
Hi jason g,
You could try these, http://www.woodfit.com/product_info....sm+600mm+R%2FH.
I have used them before for kitchen fittings and the like.
Hope this helps,
Martin
Old 05-06-2007, 3:41 PM   #4
jason g's Avatar
47,873, Level: 53
Activity: 28.0%
Cool Re: help with hardware.
thanks martin, they are what i want, the flipper door for the laptop unit and the pocket door hinge for the tv unit.
however they are too dear for me so looks like i will have to try elsewhere.
thanks for trying though.
Old 05-06-2007, 3:42 PM   #5
jason g's Avatar
47,873, Level: 53
Activity: 28.0%
cheers mate, a lot of people have said the same thing.
Old 08-06-2007, 5:40 PM   #6
jason g's Avatar
47,873, Level: 53
Activity: 28.0%
Originally Posted by martind69 View Post
Hi jason g,
Hope this helps,
Martin
got the free catalogue today i sent for but the hinges per door i want are 45 quid per door
looks like i'll have to kick the door idea into touch.
Old 08-06-2007, 5:47 PM   #7
inzaman's Avatar
22,356, Level: 36
Points: 22,356, Level: 36 Points: 22,356, Level: 36 Points: 22,356, Level: 36
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 126, Got 543
£45 per door , wow are they made of Gold
Old 08-06-2007, 8:07 PM   #8
jason g's Avatar
47,873, Level: 53
Activity: 28.0%
no steel, but i cant find them anywhere else.
