Thanks a lot for the encouragement guys. I appreciate it. I can't wait until we get this sorted. Today has been a right mare.
I'm spending so much on this home cinema that I was getting worried about little aspects especially to do with the projector and the projection screen.
As you should already know - I've gone for the HD73 and a 92" Panoview Gray Wolf screen.
The problem was that this morning I read in the projectors forum that the white screen had to be below the projector lens by a mathematically worked out figure.
The poster had just fitted a HD73 in a museum and had a right mare with it and said that for every metre of projection distance the white screen had to be 11.5cm beneath the lens. Crazy stuff as I was hoping to put my screen around 3.5m away from the screen which would mean that the screen would have to be 40cm beneath the projector.
Anyway this all sounds pretty simple and it was but I read the screen dimensions wrong and got into a right panic! All is ok now as I've measured it all up with the help of Andy (builder) and it should all fit nicely with the bottom of the screen being around 65cm off of the floor (i'm happy with that).
Anyway I've taken a few more pics for you so take a look at the latest, it has been a slow day today though:
- The ceiling has been brought down and there was already some insulation up there but we'll be putting more up.
- Cabling hanging down from ceiling - Better Cables HDMI cable and speaker cables
- Van Damme Blue series cable being run through the ceiling ready for speakers at the back of the room.
- Another of the cables hanging from the ceiling... to be finished off tomorrow.
- View from the far end of the room - HDMI cable hanging in front and part of the part time frame of the back wall. The wall is to be made stronger so that the 46" Samsung can be housed against it.
- New door way created through hallway wall. The door has been jammed in for now so that it doesn't end up falling on top of my 2 year old daughter. Once it is hinged in the surrounding area will be plastered and we'll use some spare wall paper on it to make it look normal again.
That's all I've got for today - as I said it was a slow day but hopefully tomorrow the plaster boarding will start and everything else will just kick into place. At the same time there is a a small laundry room being built on the other side so there may be days when I don't update but hey we've got three more days this week so lets see where we can get to!
Take it easy and let me know what you think...
Gags
