Moving into the garden!
Old 27-05-2007, 7:51 PM   #1
3,062, Level: 13
Points: 3,062, Level: 13 Points: 3,062, Level: 13 Points: 3,062, Level: 13
Thanks: Gave 2, Got 4
Ive decided to move into the summer house in the garden where ill be able to play music or watch movies at whatever time i want to!
thought id share my progress and mabye get pointers along the way
heres the summer house:
heres my rough plan that i nkocked up on the google sketch thingy:
The Entrance is the square space faceing you and the room at the back has a sink and used to have a portable toilet in but i think ill leave that out of my plan!
I plan to put a desk, bed, long reclining fouton bed thing, projector and screen (which im going to build), internet cable from house, small tv and all the other usual equipment.
Im also putting a stove in to keep me warm!
ill keep you updated as and when i do things although ive got 2 exams before then
Old 28-05-2007, 7:14 AM   #2
Kenny Glasgow's Avatar
12,077, Level: 26
Points: 12,077, Level: 26 Points: 12,077, Level: 26 Points: 12,077, Level: 26
Thanks: Gave 71, Got 228
Re: Moveing into the garden!
Excellent space you have there! Looking forward to the conversion
Old 11-06-2007, 7:06 PM   #3
3,062, Level: 13
finished exams! just ordered some external cat5e cable, looking for a cable to connect my ps3 to my epson tw10h projector. a hdmi to componant cable would be ideal, found this:
http://www.amazon.co.uk/Component-HD.../dp/B000N1Z8WQ
but its not long enough, ideally need a 7m or more one. dont even nkow if it would work. was going to buy a z4 from ivojo but they sold the last one on the very day i decided to take the plunge
had the stove people round should be installed end of jully at some point, picked out a nice contempory stove at half the price due to some minor scratches.
in the process of getting some screen material to build my projector screen.
Old 09-07-2007, 9:31 PM   #4
3,062, Level: 13
geting the stove installed tomorrow, bought a big 50" tv instead of useing projector, pictures to come soon.
Old 11-07-2007, 10:11 AM   #5
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
keep us all up to date with pics please, also what have you decided to use for the screen.
cheers Allan
Not another new cinema room ???
Old 12-07-2007, 8:33 PM   #6
3,062, Level: 13
Re: Moving into the garden!
nice thread youve got there!
Ive decided not too make a screen anymore due to the fact that ive got a massive tv. Its basicly a projector anyway but in a houseing.
I did buy some screen material from ebay which i was going make into a fixed frame. Instead I made a frame for the picture instead.
here are some pictures (I need to clean)
Still need to install an aerial and run an internet cable from the house , got a tempery one which goes under a few doors and through a few windows! other than that and a few touch up jobs with some paint im done. mabye add a few more pictures.
