For years I have deliberated over mounting LCD however I have never fully understood how I would get access to the rear of the TV once it is actually mounted and this has put me off.
I would be aiming for something similar to this:
Plasma in Chimney for Flush install Help
Without the centre speaker recess.
My DIY skills should be of a standard to achieve this look but I am unsure about how I would gain access to the rear of my TV and hopefully someone could offer some advice/solutions.
1. Is it a case of whilst hanging the TV you connect all your required cables etc and you simply don't get access easily after this?
2. Or, do the wall brackets have easy facilities to remove the TV from the wall then reattach it again?
3. Is it dependant on the actual bracket you use i.e. should I be looking at one of these Vogel extending brackets, pricey but look effective for what I am asking about. My only concern would be, the TV wouldn’t be as flush to the wall.
As I mentioned previously the day side of things would be straight forward enough for me, it's just I couldn't really be bothered with hassle if I wanted access to add new equipment e.g. I current only have Virgin + connected to my one and only HDMI socket, however if I decide to buy a ps3 for my son’s Xmas, how would I connect this easily?
