Bass Traps - Does Colour Matter?
Old 03-05-2007, 1:43 PM   #1
4,647, Level: 16
Points: 4,647, Level: 16 Points: 4,647, Level: 16 Points: 4,647, Level: 16
Thanks: Gave 1, Got 1
I am about to order 10 bass traps to position around a cellar. The room can easily be made very dark as only has a small window, therefore was wondering whether the colour of the bass traps around the walls is important.
The ceiling is white, the walls are also painted white, with patterned rugs on the floor.
Should I go for dark blue / black to reduce the glare?
Will probably build my own DIY screen with goo special paint.
Mark
Old 07-05-2007, 7:51 AM   #2
spooney's Avatar
9,145, Level: 22
Points: 9,145, Level: 22 Points: 9,145, Level: 22 Points: 9,145, Level: 22
Thanks: Gave 53, Got 220
Re: Bass Traps - Does Colour Matter?
Most reflections will come from your screen, the walls and the ceiling.
I would go for the aestethic approach and choose the colors which look best.
BTW: I made my screen with ScreenGoo, too, and I am very happy with it.
Old 11-05-2007, 8:23 AM   #3
miceri's Avatar
4,314, Level: 15
Points: 4,314, Level: 15 Points: 4,314, Level: 15 Points: 4,314, Level: 15
Thanks: Gave 47, Got 65
If the walls and ceiling are both white, then having darker coloured accessories won't make that much difference. You will still have a 'lightened' room when the picture is bright, less so, but still noticable on darker screens.
Only changing the colour of the walls / celing will change this...
