Home Cinema Design Help
Old 02-05-2007, 7:00 PM   #1
cinemagary's Avatar
6,548, Level: 19
Points: 6,548, Level: 19 Points: 6,548, Level: 19 Points: 6,548, Level: 19
Thanks: Gave 128, Got 10
Exclamation Home Cinema Design Help
Can anyone help....are there any UK based sites or companys where you can get help planning or ideas for dedicated Homecinema rooms as there seems to be a wealth of them in the US obviously is it a little bigger than the UK...?
Old 05-05-2007, 3:40 PM   #2
table manners's Avatar
4,402, Level: 15
Points: 4,402, Level: 15 Points: 4,402, Level: 15 Points: 4,402, Level: 15
Thanks: Gave 32, Got 73
Re: Home Cinema Design Help
if you lived a bit closer i would lend a hand to help you design a cinema room many people know what kit to buy but not much on design.have a look at my showcase thread it might give you some ideas to start with.more pics will come this week.
cinemagary (13-05-2007)
