Type of bolt for PX70 wall mount.
Old 16-04-2007, 6:29 PM   #1
norfbech's Avatar
4,527, Level: 15
Points: 4,527, Level: 15 Points: 4,527, Level: 15 Points: 4,527, Level: 15
Thanks: Gave 20, Got 20
Bit of a follow on from the wall bracket for PX70 thread...
I don't trust the bolts supplied with the Skytronic tilting wall bracket (another member here posted the heads had snapped off two already) so as mentioned by another user on these boards I'm going to use anchor bolts.
The bolts supplied required 10mm drill bit and are 95mm long...the anchor bolts which require a 10mm drill (M6) bit have a thinner thread (M6)...the slightly larger ones require a 12mm drill bit are roughly the same size as the long bolts supplied.
The M10 bolt...
Not knowing which one is surplus and which one may be a little weak for the job I'm hoping someone here uses these bolts and could possibly guide me...this is a heavy and expensive piece of equipment that I really don't want to see cascading towards my living room floor!
Cheers.
Old 16-04-2007, 6:35 PM   #2
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Points: 43,239, Level: 50 Points: 43,239, Level: 50 Points: 43,239, Level: 50
Activity: 91.7%
Activity: 91.7% Activity: 91.7% Activity: 91.7%
Thanks: Gave 465, Got 1,875
Re: Type of bolt for PX70 wall mount.
One of those you linked to would hold your telly on it's own.
You have nothing to worry about with those
I use them regularly for supporting large pipework.
Old 16-04-2007, 6:51 PM   #3
norfbech's Avatar
4,527, Level: 15
Cheers Badger - can you confirm I would be best off with the larger M10 bolt? These should still fit through the gap in the bracket (it's a tight slot).
Old 16-04-2007, 7:09 PM   #4
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
Bigger the better
Consider that the greater diameter is giving you more surface to grip.
I'd say 60mm long would be plenty, but they will do fine.
Put it this way; normal steel holds a weight of around 20 tons per square inch, so M8 should be ample.
The trick to it all, is drilling a nice neat hole.
IE don't wobble the drill about.
If it feels iffy when you tighten the bolt and doesn't tighten properly, it's a bad fix and will need re-drilling.
If it tightens fairly quickly, you know it's a good un.
But don't go ballistic when you tighten, it's not necessary.
I'm making it sound complicated, it's not really
And brick is the best you can fix to, for strength, IMO.
I'll stop rambling and just say I think they'll be fine
Old 16-04-2007, 8:23 PM   #5
norfbech's Avatar
4,527, Level: 15
Cheers Badger.
I'm having to go into the concrete lintel below the brick, but this appears to be strong enough concrete.
I usually use the big, grey raw plugs (the one's with arms!) and they've held firm lots of things...I need that extra bit of guarantee for this one though (especially with kids around).
The M6 threads are a lott smaller than the thread on the bolts supplied - the M8's just about matched, but I wanted to check for this type of 'fancy boltage'.
Many thanks.
Old 16-04-2007, 8:55 PM   #6
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
Bonus, concrete's even better
Old 16-04-2007, 9:18 PM   #7
norfbech's Avatar
4,527, Level: 15
You're more positive than I at the moment badger!
I've put dozens of shelves (usually into bad, crumbling plaster etc but have got by). This is hefty telly...once this is up and on (perhaps showing Sky at Night with Patrick Moore just to really test it ) then I'll relax!
Actually, current concern is over the length of bolt which fits through the arm of the Skytronic tilting bracket and the back of the PX70...it seems to fit ok for me yet another poster with the same set up had bolts supplied which were a couple of mm to short...brave new world all this hanging telly business!
Thanks badger.
Old 16-04-2007, 9:54 PM   #8
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
Not quite sure what you mean there, but probably that the op drilled too deep and hence it never left enough thread sticking out.
Just stick a bit of tape on the drill bit to give you an idea.
You'll be fine
Old 16-04-2007, 9:57 PM   #9
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
Oh, also, I don't know if it's three or four fixings.
If it's four, you only need to get two right and that will still be plenty, IMO.
Old 16-04-2007, 11:21 PM   #10
norfbech's Avatar
4,527, Level: 15
Badger - the concern was the bolt/s which enter the back of the plasma (4 in total) through the arm bracket of the skytronic tilting mount - the poster advised that the bolts included were 2mm short so he took out the longer bolts which prevent the bracket from self tilting and used those instead.
I have used the bolts provided and they have gone through the bracket/washer and into the TV fine - I've tightened them up sufficiently so I'm wondering why it worked ok for me...I feel as though I've missed something out and the darned thing will come a crashin to the floor when I hoist this up!
see the section which starts off in red:
Who Wall Mounted their Panny PX70?
It may be that he just wasn't supplied with the correct bolts and they've now been updated??
Cheers.
Old 17-04-2007, 4:55 PM   #11
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
No comment re your answer.
I would only say, if you've drilled them and yours are ok, having tightened nicely like I said, you've done a good job
Now try and pull it off the wall
Stop worrying, I'd trust my life to just one of those pins, correctly fitted.
In fact, I have done.
But don't tell H&S
Old 17-04-2007, 11:05 PM   #12
cloudcity's Avatar
29,058, Level: 41
Points: 29,058, Level: 41 Points: 29,058, Level: 41 Points: 29,058, Level: 41
Thanks: Gave 75, Got 50
Looks like you're more than prepared for this job.
IMO if the whole you drill feels good you've done the hard part.
And I have the big brother to that bracket and once it's up securely you've got nothing to worry about. I have done chin ups on mine and I weigh 80kg!!
Old 17-04-2007, 11:35 PM   #13
norfbech's Avatar
4,527, Level: 15
Aye - it's set up now- thanks all.
Managed to place 6 M8 95mm bolts in...the metal 'arms' of the anchors which you place in the drilled holes were a little loose (should they be...I used the correct drill bit) - I wedged a strip of cut plastic anchor just to make sure.
I had a really good push down on the bracket (attached to the concrete lintel) - strong as an ox.
Cheers folks...catch you in my 'where shall i put my av gear and wires in this brick fireplace' thread
Old 18-04-2007, 10:26 AM   #14
norfbech's Avatar
4,527, Level: 15
Here you go - completed job (bar the AV mess underneath):
Thanks for the help and advice.
Old 18-04-2007, 9:19 PM   #15
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
Great job looks nice
You'll pull the wall down before the bracket
Now you can have something to really worry about.
It looks like you have motion blur, going by that bottom picture
I'm joking , I swear
Old 19-04-2007, 7:12 AM   #16
norfbech's Avatar
4,527, Level: 15
I was actually wondering if tightening these anchor bolts would contract the whole fireplace and dislodge the brick (one of the bricks just above the lintel has cracked...can't remember if this was the case beforehand but it makes you wonder). Rock solid.
Aye - motion blur...a couple of channels to my eyes appear to show this...but what you're seeing in that pic is a slow shutter speed and not an entirely steady hand!
Cheers badger...you're not an expert in trunking are you...gotta tidy that mess of wires up soon
Old 19-04-2007, 5:23 PM   #17
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
Don't worry about it.
I know, that's why I said I was joking
Seen it done and offered my advice, but was wrong
I suggest you post another seperate question, you'll get answers, no problem
Old 20-04-2007, 2:36 PM   #18
norfbech's Avatar
4,527, Level: 15
Cheers Badge...never thought I'd be showing off my anchor bolts...but that has now happened. There was a phrase knocking about here relating to weight held per sq inch (in tons?). Can't for the life of me remember it, but one for the father in law who's making the trip up here this weekend!
And yes...I knew (hoped?) you were joking re motion blur, I'm paranoid enough as it that I've let my old CRT go to the big tv shop in the sky ...sorry...some of the SD channels aren't that good are they on Plasma/LCD's...
Will post a trunking question.
Ta.
Old 20-04-2007, 4:54 PM   #19
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 91.7%
That was posted by me in this thread
That's not the strength of a fix, that's the strength of normalish fabricating type steel.
In other words, a square inch of that stuff would hold the weight before it snapped. The elongation beforehand would be fairly drastic, but it's of no concern in this case
As I said, I've trusted my life on one of those fixings and I'm about 70 kg.
CRT is always best, but sucks, looks-wise nowadays.
Good luck with the trunking mate
Old 20-04-2007, 8:31 PM   #20
norfbech's Avatar
4,527, Level: 15
Thanks Badge (yes, CRT also take up 1/4 of your room - now the plasma is on the wall we have room to breathe once more )...hopefully when cough up for HD and a decent DVD player the CRT will be but a distant memory (and to be fair, several channels and a couple of films we've watched recently were pretty special on the 42"...certainly don't regret buying one).
Cheers for the stat also - that one's coming out tomorrow over a couple of beers (I'll probably embelish it slightly also).
...now to compose a trunking post...
ta for the advice again.
