brush face plates...where to get
Old 27-01-2007, 9:02 PM   #1
lone ranger's Avatar
7,995, Level: 21
Points: 7,995, Level: 21 Points: 7,995, Level: 21 Points: 7,995, Level: 21
Thanks: Gave 0, Got 37
i want black nickel 1s or chrome, not keen on the white 1s...where can i get them
Old 27-01-2007, 9:22 PM   #2
2,529, Level: 11
Points: 2,529, Level: 11 Points: 2,529, Level: 11 Points: 2,529, Level: 11
Thanks: Gave 4, Got 0
Re: brush face plates...where to get
homebase have a great selection the two ranges are called cassa and rocca. They have stainless, chrome, nickel.
Old 27-01-2007, 9:25 PM   #3
7,995, Level: 21
the open 1s with
brush needles in them yeh! cool will have a look
Old 27-01-2007, 10:24 PM   #4
Tesla's Avatar
6,657, Level: 19
Points: 6,657, Level: 19 Points: 6,657, Level: 19 Points: 6,657, Level: 19
Thanks: Gave 21, Got 35
I know the plates you mean, I use them on installs.
I have only EVER seen them in white though.
Old 28-01-2007, 7:47 PM   #5
7,995, Level: 21
shame really would like a nicer finish than white.
Old 28-01-2007, 9:39 PM   #6
Tesla's Avatar
6,657, Level: 19
You can get metal faceplates with the centres cut out. You insert custom modules into them.
Perhaps you could get hold of these, and some cheap letter boxes (for the bristles) and make up your own?
Old 28-01-2007, 11:14 PM   #7
7,995, Level: 21
along the lines of something i am conjuring up,the chrome ring around ceiling downlights are spring clipped and i have loads spare from my house rewire,put my own bristles in there and spring clipp holds in place over the hole, wonderful finish as it happens,proper professional and dead cheap.
Old 28-01-2007, 11:25 PM   #8
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
lets see some pics then
Old 29-01-2007, 8:24 AM   #9
MarkP80's Avatar
6,231, Level: 18
Points: 6,231, Level: 18 Points: 6,231, Level: 18 Points: 6,231, Level: 18
Thanks: Gave 112, Got 99
I bought the brush faceplate, which is a network outlet blank plate. When I looked, I'd bet money those bristles are simply lengths cut from a draught excluder which have been stuck in. I was in Wilkinsons on Saturday and saw extremely similar brush strips for door bottoms. I'm therefore tempted to cut a hole in a nickel blank faceplate, and epoxy a bit of the excluder to the back.
Cheers,
MarkP
