Blue ikea lights
Old 18-01-2007, 1:39 PM   #1
ADC ADC is offline
6,719, Level: 19
Points: 6,719, Level: 19 Points: 6,719, Level: 19 Points: 6,719, Level: 19
Thanks: Gave 184, Got 45
Blue ikea lights
Just a quick question or two before i purchase.
1. Are they as effective in the corner of a room. Ive seen plenty of pictures when they are flat against a wall. Just wondering if they look as effective as my TV is in the corner.
2. Is there a seperate switch to turn them on and off with or is it a case of flicking the plug socket on and off each time you want them on (the plug switch is difficult to get at)
Thanks in advance
Andy
P.S Pics would be nice
Old 18-01-2007, 1:49 PM   #2
Illustrious Member
Sonic67's Avatar
16,896, Level: 31
Points: 16,896, Level: 31 Points: 16,896, Level: 31 Points: 16,896, Level: 31
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 1,346, Got 1,774
Re: Blue ikea lights
I don't own the lights but you could put a switch on the flex.
http://www.maplin.co.uk/Module.aspx?...=13156&T=19549
ADC (18-01-2007)
Old 18-01-2007, 1:54 PM   #3
jason g's Avatar
47,864, Level: 53
Points: 47,864, Level: 53 Points: 47,864, Level: 53 Points: 47,864, Level: 53
Activity: 27.4%
Activity: 27.4% Activity: 27.4% Activity: 27.4%
Thanks: Gave 3,615, Got 1,639
Cool Re: Blue ikea lights
i was going to get those ikea lights but i wanted a switch too, also if the lights die u have to replace the set.
im going to get a set of lights from noodleman u will find him in the lighting section he has lights that come with a switch and if a light goes u can replace one individually.
ADC (18-01-2007)
Old 18-01-2007, 1:56 PM   #4
7,350, Level: 20
Points: 7,350, Level: 20 Points: 7,350, Level: 20 Points: 7,350, Level: 20
Thanks: Gave 100, Got 70
The IKEA Trettioen LED lights come with a switch on the power cable.
Got a set, but haven't fitted them yet. They do seem to be better (brighter) than neons IMHO.
Old 18-01-2007, 2:06 PM   #5
ADC ADC is offline
6,719, Level: 19
Could you let me know how they are when you have fitted them mate please.
Old 18-01-2007, 2:17 PM   #6
jason g's Avatar
47,864, Level: 53
Activity: 27.4%
hers the link for noodlemans site if u are interested it has some great pics, but if u still want the ikea ones then ok, just thought i would show u the site.
Lighting - TV/Stereo/Wall/Shelf Ambiant Lighting for your setup!
ADC (18-01-2007)
Old 18-01-2007, 2:19 PM   #7
7,350, Level: 20
Sure, but at the moment I'm not too sure where they're going to go....
Currently got 2 x 12" blue neon tubes behind my 32" LCD which are not as pleasing as I'd have expected. I might replace them with the 4 x IKEA LEDs or use the IKEAs elsewhere for ambience (shelving, cupboards,etc).
Old 18-01-2007, 2:20 PM   #8
Mylo's Avatar
12,988, Level: 27
Points: 12,988, Level: 27 Points: 12,988, Level: 27 Points: 12,988, Level: 27
Thanks: Gave 168, Got 402
The Ikea lights definitely do have an in line switch.
They can either be fitted using the screws or sticky pads provided. As they are LEDS they should last a very long time.
ADC (18-01-2007)
Old 18-01-2007, 2:21 PM   #9
jason g's Avatar
47,864, Level: 53
Activity: 27.4%
thats why i didnt want those lights they may be a bargain but not as good as the ones noodleman has, and u can choose what sort of set up u want.
Old 21-01-2007, 3:41 AM   #10
3,238, Level: 13
Points: 3,238, Level: 13 Points: 3,238, Level: 13 Points: 3,238, Level: 13
Thanks: Gave 2, Got 7
i'm not going to bor you with loads of pics but i have the Ikea lights and i think they great for the money
My setup is like this now as you can see the tv is on the wall in some of the pic's
ADC (21-01-2007)
Old 21-01-2007, 11:18 AM   #11
fred08
Posts: n/a
Thanks in advance
Andy
Hi ADC, I know the ikea lights are a bargain but if you got some more money to spend try this lights: http://www.av-sales.co.uk/products.php?cat=351&nav=27 I got them and the ikea light can't look that good, they light blue and very great to look at, the ikea look is a bit too hard for my point of vue. But anyway it's a personal choice. Whatever you choose, enjoy!!!
ADC (21-01-2007)
