Correct amp fuses?
Old 16-01-2007, 3:18 PM   #1
5,828, Level: 18
Points: 5,828, Level: 18 Points: 5,828, Level: 18 Points: 5,828, Level: 18
Thanks: Gave 5, Got 361
Correct amp fuses?
From the other thread I've remembered that I have used various IEC's and have mixed them up so I might have incorrectly rated fuses in the plugs. Here is my equipment- what is the recommended fuse for each item?
Poweramps
Pre-amps
AV pre-amps
PC's
CD players
DVD players
TFT displays
Old 16-01-2007, 7:50 PM   #2
5,303, Level: 17
Points: 5,303, Level: 17 Points: 5,303, Level: 17 Points: 5,303, Level: 17
Thanks: Gave 20, Got 4
Re: Correct amp fuses?
If you look closely at the plug top somewhere it might say what rating.If not check the item itself and it might give a wattage rating if its anywhere round
690 watts = 3 amp
1150 watts =5 amp
2990 watts =13 amp
I hope thats right cause im a bit rusty at the maths,ive given ya the power formula below
watts=voltage*amps
voltage=watts/amps
amps=watts/voltage
