M D F painting
Old 16-01-2007, 3:10 PM   #1
chaz's Avatar
10,091, Level: 24
Points: 10,091, Level: 24 Points: 10,091, Level: 24 Points: 10,091, Level: 24
Activity: 21.8%
Activity: 21.8% Activity: 21.8% Activity: 21.8%
Thanks: Gave 11, Got 10
M D F painting
HI i have some M D F units iwant to paint them white i dont relly want to use oil paint as it looks a bit yelloshwhen dry is there a make of paint that relly looks white when fished and what sort of base coat do i use for M D F ta
Old 17-01-2007, 7:44 AM   #2
clockworks's Avatar
9,570, Level: 23
Points: 9,570, Level: 23 Points: 9,570, Level: 23 Points: 9,570, Level: 23
Activity: 62.2%
Activity: 62.2% Activity: 62.2% Activity: 62.2%
Thanks: Gave 137, Got 319
Re: M D F painting
You can use car paint on MDF with no problems. Acrylic spray cans (standard Halfords) work well, although it might get expensive for a big cabinet. Might be better to hire a spray gun, and buy a tin of white base (and the appropriate thinners) from an automotive refinishing supplier.
Car primer will work OK, too, although you can get specialised MDF primer from B&Q, IIRC. Pay particular attention to the "end grain" of cut boards, as this area will need extra sealing - the cut ends are very porous. If you don't seal them properly, you'll get a matt finish.
My brother made some house signs from MDF. He sprayed them with cellulose primer and colour, airbrushed the lettering, then sealed them with 2-pack laquer. They've been outside for 5 years, and are in perfect condition.
Old 17-01-2007, 10:25 AM   #3
45,485, Level: 52
Points: 45,485, Level: 52 Points: 45,485, Level: 52 Points: 45,485, Level: 52
Activity: 21.6%
Activity: 21.6% Activity: 21.6% Activity: 21.6%
Thanks: Gave 378, Got 854
Re: M D F painting
is there any way to get a really good gloss finish? Would using a spray help with that? Can you clearcoat MDF?
Old 18-01-2007, 1:56 AM   #4
dirtrun
Posts: n/a
Re: M D F painting
Have been reading on DIY screens for Front Projection and some say that MDF's can warp , what if it is in a room and not outdoors, will it still warp?
Am thinkin of getting de goo systems paints and doing up either an mdf or plywood as a screen, is this feasible?
Sorry total noob in this...
Thanks for reading
Dirtrun
Old 18-01-2007, 7:42 AM   #5
clockworks's Avatar
9,570, Level: 23
Activity: 62.2%
Re: M D F painting
If you are good with a spraygun, you can achieve a perfect glasslike finish. Automotive clearcoat can take a much better finish than DIY varnish/laquer.
With the correct equipment, and good preparation, you can get a perfect finish "straight from the gun" if you use 2-pack clearcoat. Acrylic or cellulose will need a bit of flatting/compounding.
Old 18-01-2007, 10:51 AM   #6
jason g's Avatar
47,864, Level: 53
Points: 47,864, Level: 53 Points: 47,864, Level: 53 Points: 47,864, Level: 53
Activity: 27.4%
Activity: 27.4% Activity: 27.4% Activity: 27.4%
Thanks: Gave 3,615, Got 1,639
Cool Re: M D F painting
Originally Posted by dirtrun View Post
Thanks for reading
Dirtrun
mdf doesnt warp as far as i know of have a look at this and see for yourself,
http://www.merbok.com/mdfoverview/whatis.htm
u can get 18mm mdf which is quite thick, not sure if u can get bigger thickness than that or not, not sure about plywood sizes.
wickes have thick mdf in this link too.
http://www.wickes.co.uk/icat/smmdfsheets
im going to build my units in my bedroom in mdf and im going to use b and qs paint and grain u put the base coat on and then the grain coat then u buy a varnish probably clear, and give it a couple of coats, u can get different colours in paint and grain too, have a look.
http://www.ronseal.ie/prodshowgroup....in&intext=int#
click on colours next to add to shopping for a choice.
it even has a guide on here of how to use it.
hope this info helps and if u do use it i would like to see the result if u could show a pic.
