Advice for fitting Servo-15 in a Cabinet.
Old 07-01-2007, 11:04 AM   #1
4,868, Level: 16
Points: 4,868, Level: 16 Points: 4,868, Level: 16 Points: 4,868, Level: 16
Thanks: Gave 3, Got 4
In a bid to tidy the front of the room I'm putting all of my equipment in a cabinet.
This means that my sub will also go in there.
I was planning on Close-fitting the sub on three sides with the sub on the floor and the rear left open for ventilation. Would it be just a case of putting some sound-absorbant wadding around the sub inside the cabinet and making sure the driver is as flush with the face of the cabinet as possible?
Has anyone done this?
Does anyone have any advice?
Old 09-01-2007, 12:45 PM   #2
jeepjunkie's Avatar
2,597, Level: 11
Points: 2,597, Level: 11 Points: 2,597, Level: 11 Points: 2,597, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 3, Got 3
Re: Advice for fitting Servo-15 in a Cabinet.
Not sure if this helps but I have tried two similar things. 1) Put my Bose bass module in a cupboard in the living room pointing it through the lourve doors which worked brilliantly, very discrete. 2) Had one of the smaller M&K subs inside a custom hi-fi cabinet that had no back with the door inset with speaker fabric. This also worked very well. Cheers Colin
