Mounting sockets in skirting
Old 11-12-2006, 8:18 AM   #1
sjuggins
Posts: n/a
Have any of you ever mounted your sockets into the skirting boards?
I was contemplating doing this in my new house but not sure what it would look like, tried looking for some pics but couldn't find any. I like the idea of keeping the walls uncluttered.
Any links or pics would be great
Old 11-12-2006, 8:27 AM   #2
scouse258's Avatar
Thanks: Gave 1, Got 5
Re: Mounting sockets in skirting
in older houses you find that most sockets are in the skirting boards. i may be wrong but new laws now require them top be of a certain height from the floor (12 or 18 inches?) im not a sparky but read it somewhere
Old 11-12-2006, 8:37 AM   #3
Alun's Avatar
8,068, Level: 21
Points: 8,068, Level: 21 Points: 8,068, Level: 21 Points: 8,068, Level: 21
Thanks: Gave 303, Got 259
http://www.iee.org/Publish/WireRegs/...luminaires.pdf
According to the regs, minmum recommended mount height of 450mm
All I know is that none of mine are mounted that high!
Only thing I would say is that it might make hoovering etc a bit tricky.
Old 11-12-2006, 8:42 AM   #4
sjuggins
Posts: n/a
Cheers guys.
Well it looks like they'll all be mounted at 450mm from the floor then, I've got to conform to building regs as it's a complete re-wire and need building control approval.
Didn't think about the hoovering, good point.
Old 11-12-2006, 3:12 PM   #5
jonny round boy's Avatar
8,448, Level: 21
Points: 8,448, Level: 21 Points: 8,448, Level: 21 Points: 8,448, Level: 21
Thanks: Gave 0, Got 13
The regulation which states 450mm minimum applies to NEW BUILDS/CONVERSIONS ONLY.
In an existing property, you can put them at whatever height you like!
Old 11-12-2006, 4:21 PM   #6
Conspicuous Member
eviljohn2's Avatar
20,356, Level: 34
Points: 20,356, Level: 34 Points: 20,356, Level: 34 Points: 20,356, Level: 34
Thanks: Gave 79, Got 225
If you are installing them at ground level, it's normally a good idea to mount them upside down so that the cable comes straight up rather than jammed down into the floor.
Old 11-12-2006, 4:35 PM   #7
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
not sure if the same regs cover AV cables that covers mains interms of mounting and i have known people get the wiring signed off then move all the sockets back down i currently live in a new flat with low switches and high sockets and it can be a pain but its no real issue (its so people in a wheel chair can reach, 2nd floor flat no lifts! Figure that out they could get into the flat but could plug in a hair dryer!)
Old 11-12-2006, 9:22 PM   #8
5,112, Level: 16
Points: 5,112, Level: 16 Points: 5,112, Level: 16 Points: 5,112, Level: 16
Thanks: Gave 0, Got 6
or you could floor mount them.
