Mine was similar,so I drilled 40mm - 50mm diameter holes (or whatever size hole cutter you have) through the plasterboard where I was fixing the bracket,then filled the holes with plasterboard adhesive flush to the plasterboard.Plasterboard adhesive is very strong and ideal for this.
These were the results.
I then bought a box of
these and drilled 16mm (dependant on size of studding) holes into the plasterboard adhesive and into the block wall behind making sure the holes were deep enough to leave enough stud protruding out of the wall to clear the bracket and to get a washer and nut on.
I also bought 1 of
these and injected into the holes then pushed the studding in whilst rotating to get good coverage.It sets very quickly,about 20 mins or so and is very,very strong.
If the clearance between the studding and holes in bracket isn't large,you can always get smaller diameter studding,and a sure way of making sure the studding is set in the walls in line so you can get the bracket on after the studs are set,is after you have drilled the holes for the studding, screw the bracket to the plasterboard using a couple of rawlplugs and screws to take the weight of the bracket and square up using a level making sure holes in bracket line up with holes in wall.
Then,inject the resin into the wall through the holes in bracket,and then insert the studs through the bracket,then you are guaranteed that everything lines up and the bracket will be square when you tighten everything up.I injected one hole then inserted stud and so on,as I said earlier,it doesn't take long for resin to set.
I used 9 studs because I had them,but I'm sure 6 will be well strong enough.
Hope this helps.
