Conduit
Old 22-06-2002, 9:56 AM   #1
Conspicuous Member
stevegreen's Avatar
30,635, Level: 42
Points: 30,635, Level: 42 Points: 30,635, Level: 42 Points: 30,635, Level: 42
Thanks: Gave 1,182, Got 1,020
Conduit
Can anyone tell me where i can buy thin pvc self adhesive electrical conduit to run my speaker wires through?
It needs to be as thin and shallow as possible so its hardly noticable under coving. Local electrical retailer sells half inch conduit but im wondering if there is anything smaller.
Old 22-06-2002, 10:36 AM   #2
JohnS's Avatar
9,453, Level: 23
Points: 9,453, Level: 23 Points: 9,453, Level: 23 Points: 9,453, Level: 23
Thanks: Gave 6, Got 30
Try asking for self adhesive alarm cable conduit, it comes in much smaller sizes.
Old 22-06-2002, 10:37 AM   #3
Conspicuous Member
stevegreen's Avatar
30,635, Level: 42
Cheers John............
Will try that one.
Old 22-06-2002, 9:46 PM   #4
8,335, Level: 21
Points: 8,335, Level: 21 Points: 8,335, Level: 21 Points: 8,335, Level: 21
I got some really thin stuff from B&Q
Old 24-06-2002, 1:42 PM   #5
Dominic's Avatar
5,132, Level: 16
Points: 5,132, Level: 16 Points: 5,132, Level: 16 Points: 5,132, Level: 16
Thanks: Gave 0, Got 6
try screw fix, i have seen it on a roll from them ( slef adhesive) if not get some 16mm stuff from B&Q etc and use some "no nails " or simular ( thats what my trunkings is on the ceiling with...
http://www.screwfix.com
Old 24-06-2002, 1:46 PM   #6
Conspicuous Member
stevegreen's Avatar
30,635, Level: 42
Thanks a lot lads................some good idea's there..........all to keep the missus happy!
Old 09-07-2002, 8:15 PM   #7
15,822, Level: 30
Points: 15,822, Level: 30 Points: 15,822, Level: 30 Points: 15,822, Level: 30
Thanks: Gave 583, Got 289
What diameter do you require.Microbore,10mm and 8 mm is available cheaply. Details
