"A Scanner Darkly effect"
Old 14-09-2006, 4:43 PM   #1
11,214, Level: 25
Points: 11,214, Level: 25 Points: 11,214, Level: 25 Points: 11,214, Level: 25
Thanks: Gave 5, Got 47
I would like to produce some artwork of my family to decorate my HT in the style of the film "A Scanner Darkly". Does anyone know of a company or a software package that could produce this kind of image or similar?
Old 14-09-2006, 4:51 PM   #2
5,545, Level: 17
Points: 5,545, Level: 17 Points: 5,545, Level: 17 Points: 5,545, Level: 17
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 73, Got 209
Re: "A Scanner Darkly effect"
There's quite a long thread here with tips and techniques for using Photoshop etc. to recreate the look.
regards
Brian
Old 14-09-2006, 6:40 PM   #3
11,214, Level: 25
Thanks, I will check it out, I dont have photo shop, I was hoping to find someone who could do it for me
Old 14-09-2006, 8:35 PM   #4
5,545, Level: 17
Activity: 3.9%
I'd be happy to give it a go if you like. PM me some details and suitable photos if you have them.
regards
Brian
Old 15-09-2006, 9:08 AM   #5
11,214, Level: 25
Thanks Brian, I will sort out some images over the weekend and email them across. What I am trying to do is get the images printed on to canvas or speaker material which I can then mount onto a frame. I will then install some kind of accoustic material behind the image to create a room friendly accoustic tratment, well that the idea anyway.
