Hiding cables behind skirting boards?
Old 06-09-2006, 12:29 PM   #1
mjn mjn is offline
18,266, Level: 32
Points: 18,266, Level: 32 Points: 18,266, Level: 32 Points: 18,266, Level: 32
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Thanks: Gave 218, Got 612
Currently about to start the process of decorating every room in the house, and as such i want to take advantage of all the rooms being bare.
What is involved in putting CAT5 cables behind skirting boards?
Basically, i want to hide most cables, and put CAT5 points in all rooms. It is only a 2 bed terrace, not a mansion or anything.
Ideas, please.
Old 06-09-2006, 1:43 PM   #2
Bacus's Avatar
7,447, Level: 20
Points: 7,447, Level: 20 Points: 7,447, Level: 20 Points: 7,447, Level: 20
Thanks: Gave 486, Got 342
Re: Hiding cables behind skirting boards?
mjn,
Do you have a router ?? if so when you have removed the skirting board simply route out on the back the amount (size) chanel you need for your cables. Its not to bad a job to do. Or if you are replacing the skirting boards with new, then you can buy then already channeled out. !!!
Old 06-09-2006, 1:47 PM   #3
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
Thanks, thats what i just reading about. What about the tight 90 degree corners though? and doorways?
Not many cables like being bend through 90 degree, plus some of the cables i have are very thick.
Old 06-09-2006, 1:56 PM   #4
mhuk05's Avatar
14,581, Level: 29
Points: 14,581, Level: 29 Points: 14,581, Level: 29 Points: 14,581, Level: 29
Thanks: Gave 31, Got 128
It's easier to go wireless
Old 06-09-2006, 1:59 PM   #5
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
I could, but i'd rather have a wired network, its more secure for starters, and i have a 1000 network which i'd like to keep.
Ideally i'd like to put speaker, mains and video cable hidden away as well
Old 06-09-2006, 2:01 PM   #6
Bacus's Avatar
7,447, Level: 20
Then you could HIRE a wall chasser !! Remove your skirting boards,but mark out the top of them on the wall first. Then chase out the wall !! BUT it is a very dusty job so keep the doors shut and get everything out of the room !!
In the corners of the walls where they return at 90 degrees use a hammer and bolster to chase out a bit deeper to allow you to put a shallow bend in the cables.
Old 06-09-2006, 2:03 PM   #7
Bacus's Avatar
7,447, Level: 20
mjn,
How old is the house ? can you not go under the floor ?
Old 06-09-2006, 2:03 PM   #8
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
Ok, thanks for that.....think i'll keep that as my backup option
For the bedrooms, i think a simple router in the skirting boards for the CAT5 will be ok.
It's only the front room that needs the extra work.
Old 06-09-2006, 2:05 PM   #9
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
Originally Posted by sikenny
mjn,
The house was built in 1941, i haven't lifted the carpet in the front room yet, but i do know that they are floor boards, so i have the option of lying cables between the joists.
Old 06-09-2006, 2:06 PM   #10
Bacus's Avatar
7,447, Level: 20
This way would be a lot less work !!
Old 06-09-2006, 2:11 PM   #11
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
But isn't removing T&G floorboards a right pain in the a**?
Unless there is a trick to it?
Old 06-09-2006, 2:15 PM   #12
Bacus's Avatar
7,447, Level: 20
Quite an old house !! are you sure its T&G flooring
Old 06-09-2006, 2:17 PM   #13
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
mmmmm...you've got me 2nd guessing now..i'm 95% certain it is, but i'm gonna have to check now (well later, when i get home)!
If it isn't, then the job just got a whole lot easier!!
edit: The g/f says that there is plywood over the floorboards, but she thinks that they aren't tongue and groove. But i only had a quick look when we moved in about 1 year ago.
Old 06-09-2006, 2:25 PM   #14
Bacus's Avatar
7,447, Level: 20
My first house a little o cottage (bless) was built in 1830 and was the old standard inch thick floor boards.
If yours is T&G then the best way is to cut a trap in the floor about 6 inches square from the point you want to run the cables to the point you want them to come up again. So a trap each end. Then feel the cables between the 2 traps. When you go to replace the bit of flooring you have cut out for the trap,fix some battern around the underside of the trap opening so that it is half exposed and half under the origional floor(fixing points) then when you place the bit of flooring to cut out it wont fall through the hole and you can always get access at a later date !!
Old 06-09-2006, 2:31 PM   #15
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
Cool, thanks for all the advice!
I'll let you know how things work out!!
Old 06-09-2006, 2:35 PM   #16
Bacus's Avatar
7,447, Level: 20
No worries, just ask if you want to know anything else, and if i can ill answer. Good luck
Old 16-10-2006, 10:26 AM   #17
mjn mjn is offline
18,266, Level: 32
Activity: 4.4%
I thought i'd start small, so started with the main bedroom, and all went according to plan. Mind you, some of the floor boards got broken when being removed, and had to be replaced, but they must have been 40 years old anyway.
