Ceiling Question
Old 31-08-2006, 3:46 PM   #1
lutonian's Avatar
4,401, Level: 15
Points: 4,401, Level: 15 Points: 4,401, Level: 15 Points: 4,401, Level: 15
Thanks: Gave 140, Got 40
Ceiling Question
I would like to secure another layer of plasterboard to the existing ceiling in my garage conversion.
The current construction is roofing (metal & tiles)/wooden frame/rockwool/waterproof membrane/1 layer of plasterboard/skimmed plaster.
What is the best method of doing this ?
Lutonian
Old 31-08-2006, 4:17 PM   #2
dazza1011's Avatar
2,340, Level: 11
Points: 2,340, Level: 11 Points: 2,340, Level: 11 Points: 2,340, Level: 11
Thanks: Gave 238, Got 546
Re: Ceiling Question
not sure why you would need 2 lots of plasterboard
but any way
I would always try and use 12.5mm plasterboard,( if its for sound insulation or heat insulation call at a builders merchants as they have special foil backed plasterboard etc ) taper edge if you're tape and fillng it as opposed to plastering.
Use screws to fix it as well, proper gyproc ones not just woodscrews, [FONT="Arial Black"]make sure when you go to the suppliers you tell them what you are doing dont worry about looking daft you look even dafter going back after the thing has fallen down [/FONT].
find the joists and make sure you stagger them also get a mate to help you as they are bloody arkward
Old 31-08-2006, 4:19 PM   #3
lutonian's Avatar
4,401, Level: 15
hi,
cheers for the advice. i need the extra lay to help with sound proofing and insulation.
lutonian
Old 31-08-2006, 4:27 PM   #4
dazza1011's Avatar
2,340, Level: 11
if you really want to go to town how about this
http://www.domesticsoundproofing.co.uk/ceiling.htm
they say to use their products but you could probably pick them up from a decent builders merchants ( try and stay away from B&Q ) and if you pay cash they might knock something off
good luck
Old 31-08-2006, 5:35 PM   #5
7,384, Level: 20
Points: 7,384, Level: 20 Points: 7,384, Level: 20 Points: 7,384, Level: 20
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 37, Got 108
This might be helpful http://www.greengluecompany.com/upgr...tingFloors.php
