electric roller blinds
Old 15-05-2002, 2:06 PM   #1
checkout3
Posts: n/a
Can anybody advise me on the best type of blind to use to black out my home theatre room. I would like them to be electric. Has anyone heard of electroglide?
Old 16-05-2002, 11:08 PM   #2
ReTrO's Avatar
15,958, Level: 30
Points: 15,958, Level: 30 Points: 15,958, Level: 30 Points: 15,958, Level: 30
Thanks: Gave 14, Got 51
Not heard of Electron Glide. Only people I can think of that might do electric blinds, or know of someone who does, is Silent Gliss, based in Kent.
Try www.silentgliss.co.uk and email them.
Old 18-05-2002, 10:44 PM   #3
checkout3
Posts: n/a
Electric Blinds
Thanks Richard for your input, I will check them out tomorrow.
Old 19-05-2002, 8:28 PM   #4
Posts: n/a
Electric blinds
Hi There,
I am in the process of converting my loft into a Home Cinema, and I have a Velux window, which I have purchased a Electric black out blind, from Velux. This is battery operated, 1000 openings per battery, one downer, they are quite expensive.
Old 04-03-2005, 12:16 PM   #5
avbill
Posts: n/a
Electric blinds
We have just done a large install with Amx, Polaron etc and our customer wanted electric blackout blinds and romans (always a problem) .We found a company how carried out the installation from start to finish do I need to say anymore............... see the website farnborough Blind Co Limited
We used there Cm1 control unit? for voltage trigger and Relay Modules Cm1 control unit
Its about Time!!!!
Old 04-03-2005, 1:21 PM   #6
4,382, Level: 15
Points: 4,382, Level: 15 Points: 4,382, Level: 15 Points: 4,382, Level: 15
Thanks: Gave 1, Got 14
There's also Somfy blinds. Never tried them though - but I'll be thinking about it soon so let us know how you get on.
Old 04-03-2005, 2:17 PM   #7
avbill
Posts: n/a
I have used somfy motor projection screens but not somfy blinds.
please let me know as i do get a lot of enquires for electric blinds.
Old 26-04-2007, 6:01 PM   #8
DaveJ-UK's Avatar
2,491, Level: 11
Points: 2,491, Level: 11 Points: 2,491, Level: 11 Points: 2,491, Level: 11
Activity: 0.2%
Activity: 0.2% Activity: 0.2% Activity: 0.2%
Thanks: Gave 1, Got 0
Re: electric roller blinds
What kind of prices are they? I'm struggling to find much on the web.
EDIT: Sorry to resurrect such an old thread!
Old 21-04-2009, 2:49 PM   #9
Farris's Avatar
Thanks: Gave 27, Got 6
I need to buy 5 black out blinds and Silent Gliss are very expensive.
Silent Gliss coss about £1k per window and this is for a relatively normal size about half wall weight and not that wide.
What costs are associated wiht Velux and others?
