Wall connectors
Old 07-05-2002, 10:40 AM   #1
Tone
Posts: n/a
Cool Wall connectors
Wondered if any one can help me.
I am installing my home cinema system and hiding all cables under
floorboards before we lay flooring. I have found speaker and phono boxes
that sit in the walls like plugs, and allow me to plug the speakers etc into
them. I am having problems finding anything that would allow me to have
s-video leads coming up through the wall.
Does anybody know of any wall plug or similar that would allow this
Old 08-05-2002, 4:21 PM   #2
Laura's Avatar
8,076, Level: 21
Points: 8,076, Level: 21 Points: 8,076, Level: 21 Points: 8,076, Level: 21
Thanks: Gave 18, Got 24
LetsAutomate.com have some surface mount boxes that sound about right.
http://www.letsautomate.com/walloutlet.cfm
laura.
Old 08-05-2002, 5:26 PM   #3
Tone
Posts: n/a
Cool Thanks for your help
Laura, thanks for your reply that's a great help
Old 10-05-2002, 8:34 AM   #4
ReTrO's Avatar
15,958, Level: 30
Points: 15,958, Level: 30 Points: 15,958, Level: 30 Points: 15,958, Level: 30
Thanks: Gave 14, Got 51
Avoid wall box connections if you can. Adding extra joins to the cable run just degrades the picture/sound quality.
You'd be better off just running the cables out of the walls straight into your speakers/equipment.
